Put truck and car on same trickle charger for a month?
   / Put truck and car on same trickle charger for a month? #11
In general, lead acid batteries self-discharge (assuming no "phantom" loads), about 3 to 5% per month, less if colder and more if warmer. As others have posted, not much worry either way. If it'll make you feel better, charge the tractor for several days, then switch it to the truck before you leave.
A good trickle charger (of which Harbor Freights offering is *not*) will not boil the electrolyte out of any regular sized lead acid battery. Why to I dis the HF offering? Check the voltage . . . the several I purchased were putting out less than 13 volts. A trickle charger should, at room temperature, put out more like 13.7 to 13.8 volts - an appropriate "float" charge.
BTW, there are many "intelligent" battery maintainer chargers out there. Good ones will put out an amp or two, then as the battery voltage rises and charge current drops, they will switch over to a lower, maintenance charge mode. More better than the older, constant voltage trickle chargers like HF and others sell.
bumper
   / Put truck and car on same trickle charger for a month? #12
   / Put truck and car on same trickle charger for a month? #13
A good trickle charger wouldn't hurt anything. From what I have read it's always one trickle charger per battery. No jumping. As far as Harbor Freight stuff? Yeah, that could burn my house down. The make some nice battery maintainers these days that have microprocessors in them. They are not cheap but are a lot cheaper than a new house.
   / Put truck and car on same trickle charger for a month? #14
I work a month at a time on the lower Mississippi River, my truck used to set at the STL office during that time period. It has set other places also, I have been doing this for twenty years now. Sometimes it sets in 0 degree temps. I've never had any battery issues. Your vehicles will be fine, leave them both full of fuel to avoid condensation issues, which I wouldn't really worry about either. LUTT
   / Put truck and car on same trickle charger for a month? #15
I would not hook a trickle charger to two vehicles. Load balance issues as noted previously.
I might consider a trickle charger for both, but only the type that senses the charge and turns on/off as needed(maintenance charger). All of our fire engines have them, especially the reserve engines.
Easiest would be just disconnect the batteries. Good opportunity to clean the posts/terminal etc too. Worst case give them a little maintenance charge when you get home, and then reconnect them.
   / Put truck and car on same trickle charger for a month? #16
run them both for 10 minutes before you leave, to top off the batteries .... forget the charger ...
   / Put truck and car on same trickle charger for a month? #17
If your batteries won't hold charge for a month without a "maintainer" connected you need new batteries. I have 3 vehicles setting that don't get started/driven but once every 2 - 3 months and have no battery issues with them, just when I do start them I run for at least a hour. Put the trickle charger on each battery for 24 hours 3-4 days before leaving and don't worry about them. I charge my boat batteries at the end of October, leave them set all winter and they are still good in early April when I'm ready to go again.
   / Put truck and car on same trickle charger for a month? #20
Also aqree do nothing. In fact I would disconnect as many electrical outlets as possible if going away for even a week. And turn water off too. Any problem is covered by the law that states it will happen when you have just left, not 5 mins before you get back.
Year: 2014 Make: Ford Model: Explorer Vehicle Type: Multipurpose Vehicle (MPV) Mileage: Plate: Body (A51694)
Year: 2014 Make...
UNUSED JCT 40' CONTAINER (A51244)
UNUSED JCT 40'...
2011 Ram 1500 4x4 Crew Cab Pickup Truck (A50323)
2011 Ram 1500 4x4...
2019 Ford F-150 4x4 Ext. Cab Pickup Truck (A50323)
2019 Ford F-150...
Ford 3pt Plow (A50121)
2012 Ford F-150 Pickup Truck (A50323)
2012 Ford F-150...
