Compact Tractor Newbie - Whats the appropriate attachment?
   / Compact Tractor Newbie - Whats the appropriate attachment? #1
tractorslt
western, massachusetts
Mahindra Max 28 w/ Loader
So im new to the tractor scene, and i recently purchased about 30 acres of raw, wooded land. I recently purchased a 28 hp sub compact tractor with a class 1 3pt hitch. A section of the land was partially logged 15-20 years ago, and I'm looking to open up a 1-2 acres food plot. My plan is to drop/clear the tree's, and work around the stumps(which are spaced pretty far apart) for the time being. My question is: What is the best attachment to use to break the soil that has roots/occasional big(2-3') rocks? Or, atleast, what attachment would I start with?
Thanks.
   / Compact Tractor Newbie - Whats the appropriate attachment? #2
Racket rake would do that assuming you have a loader.
   / Compact Tractor Newbie - Whats the appropriate attachment? #3
Welcome from Wisconsin
   / Compact Tractor Newbie - Whats the appropriate attachment? #4
Ratchet Rake is an excellent attachment for tearing out brush but time consuming for scratching up two acres of ground prior to seeding.
Most often a Disc Harrow is used to open the dirt for food plots, then the ground is seeded, then seed is rolled in with a Cultipacker.
Your Max can't quite handle an Disc Harrow with 18" pans, the minimum weight required to cut the surface, and rocks eliminate a PTO powered roto-tiller, so I recommend a Tufline 2/22" Disc Plow.
Used Disc Plows show up regularly on eBay, Ken Sweet, Sweet Tractors in Kentucky, being reliable. You do not want too heavy a Disc Plow for the Max.
An alternative would be any of numerous "No-Till" food plot mixtures, based on clover. Clover seed is very small and is NOT rolled in.
Rolling in most seed for good ground contact/adequate moisture take-up, is important, Clover being an exception. Do not seed until rain is forecast. An improvised drag will do, a roller is better; a Cultipacker is best.
NOW is the time to plant a winter food plot at the higher elevations in Massachusetts.
LINKS:
http://www.ratchetrake.com/images/ratchet_rake_brochure.pdf
http://www.tractorbynet.com/forums/kubota-owning-operating/146060-ratchet-rake-ever-seen-used.html
http://www.monroetufline.com/pdf/TDP Discplow (47990).pdf
Everything Attachments Cultipacker 5' with smooth wheels
So maybe just a rake to clear debri/scratch up the soil would be better for a no-till plot?
   / Compact Tractor Newbie - Whats the appropriate attachment? #6
Your tractor may mash up the ground enough as you remove trees to make No-Till a reasonable proposition with no other prep. Cleaning up is certainly better.
You can plow in the late Winter then plant a Spring/Summer grain mix after final Spring frost.
In Florida, Ace Hardware and Southern States Co-ops are good sources for low price 40-50 pound bags of food plot seeds. Walmart has seed on a hit-or-miss basis, in Sporting Goods. Clover is a premium price.
Many web venders but freight increases net cost.
   / Compact Tractor Newbie - Whats the appropriate attachment? #8
A Ratchet Rake on your bucket will work better for piling/moving debris than a Landscape Rake on the Three Point hitch.
Yea, i took a look at a couple of youtube videos on a ratchet rake. It might be my best bet to get one and keep it simple with a throw n grow/no till type seed...and maybe line the area with some apple trees. Thanks for the input guys.
2013 KENWORTH T800 DAY CAB (A53426)
2013 KENWORTH T800...
2020 John Deere R4023 Sprayer (A53342)
2020 John Deere...
2011 Wacker Neuson RD12A, 36" Double Drum Roller (A52384)
2011 Wacker Neuson...
1837 (A51248)
1837 (A51248)
2018 UTILITY VS2RA 53FT REEFER TRAILER (A53426)
2018 UTILITY VS2RA...
