Hot climate hood vent-Ford F550
   / Hot climate hood vent-Ford F550 #1
Wnc3
Gold Member
S.E., Texas
John Deere 820 utility, John Deere 5525, 997 JD Zmower, Komatsu PC 35 miniExcavator
We did this to improve A/C, cooling and battery life. A/C improved a lot. Too soon to tell on batteries.
Truck idles a lot.
Anybody else try this? This was the cheapest way I could think of with no body work. image.jpgimage.jpg
   / Hot climate hood vent-Ford F550 #2
If that doesn't work, you can always add a "camper style" power roof vent.
   / Hot climate hood vent-Ford F550 #3
I have always just pulled the seal out and if that was not enough shim the hinge with washers to raise the rear of the hood a bit. In the great white north I do it to keep the windshield wiper area free from ice and snow. Works good to about 20 below then nothing helps on the plow trucks other than a warm garage. Used to shim the hoods on the drag cars to help with cooling. CJ
Wow, thanks....
I got the boat scupper idea from the van style ambulances I had seen it done on.
Form follows function, but I guess in this case maybe not. Lower profile might look better, but I could not find any.
   / Hot climate hood vent-Ford F550 #7
have you had the washer nozzles/hoses melt yet? Had mine idling in near Houston and it melted the hoses off the hood!
No we have not, but we have put these on all the trucks except on. No battery failures and the a/c works better at idle.
Also, all that under hood heat can't help the other accessories and engine components. we can install the scuppers in less than 30 minutes. Run Cool Hood Louvers are nice, but are more involved to install and are relatively expensive for what they are.
I will post a picture of some we installed on a Dodge 3500 when I have a chance.
what color is your hood? Black is really hot compared to white...
   / Hot climate hood vent-Ford F550 #9
Truck idles a lot.
Anybody else try this? This was the cheapest way I could think of with no body work.View attachment 388715View attachment 388716
Wnc3,
Good looking job!! It gets to the point, on the cheep ! ! ! !:laughing: If that doesn't quite do the job, try putting on 2 more and see what happens. Putting louvers into the hood is VERY costly the last time I checked into it. :2cents:
Dave
   / Hot climate hood vent-Ford F550 #10
Wnc3,
Dave
If you need more air flow take another page from the marine world and put in a 12v bilge blower like this. They really move the CFM's. You can even get fancy and put in a relay so it's only powered when the vehicle is on and a thermostat to control it for a predetermined under hood temperature.
Attwood Turbo 3000-3 Blower White ATT-17334, Boat Parts and Accessories
Chris
2018 CATERPILLAR 259D SKID STEER (A51246)
2018 CATERPILLAR...
2021 BOBCAT T450 SKID STEER (A51246)
2021 BOBCAT T450...
2009 Freightliner M2 106 MedTec Ambulance (A51692)
2009 Freightliner...
2014 CAT  299D TRACKED SKID STEER (A53843)
2014 CAT 299D...
2022 BOBCAT T76 PLATINUM R SERIES SKID STEER (A51246)
2022 BOBCAT T76...
