I need a couple of BX2750 snowblower pictures
   / I need a couple of BX2750 snowblower pictures #1
Jay4200
Hudson/Weare, NH
L4200GST w/ LA680 & BX2200D w/ LA211
My basket-case of a BX2750 snowblower was ground-down across the bottom, wearing off both the blade and chassis edges, so everything is flush but I think about 1/2" short. Luckily, the chassis wasn't worn all the way up into the cutting edge bolt holes. I am doing a little re-engineering and fabricating some heavy-gauge reinforcements. I am making new chassis siderails, but I'm not sure of the relationship between the bottom edge of the sides of the blower body and the scraping blade edge. If somebody could post a picture of that portion of the blower showing one of the lower corners of the chassis and how the blade and body are oriented vs each other, I'd be forever grateful.
   / I need a couple of BX2750 snowblower pictures #2
Does this help?
Sent from my iPad using TractorByNet
Does this help?
Almost - so the front edges (curved) of the chassis float above the blade - do the rear sections sit flush with the ground (even with the cutting edge) on this picture? A side view a little closer up would show it. My plan is to beef up the side rails to make them flush to just a CH lower than the cutting edge - that's how my big 3pt blower is set up.
Thanks!
   / I need a couple of BX2750 snowblower pictures #7
How about this?
   / I need a couple of BX2750 snowblower pictures #8
Yup - and not a single one shows what I asked to see.
Instead of people guessing at the right angle and location that you're looking for, why not take a picture of yours showing exactly where and how close up you want it?
2018 Bobcat T590 Two Speed Compact Track Loader Skid Steer (A50322)
2018 Bobcat T590...
2006 International 4400 LP Ambulance (A50323)
2006 International...
CATERPILLAR 325FL EXCAVATOR (A51242)
CATERPILLAR 325FL...
UNUSED CFG Industrial MX15RX Mini Excavator (A47384)
UNUSED CFG...
2008 INTERNATIONAL DURASTAR 4300M7 SBA 4X2 DUMP TR (A51243)
2008 INTERNATIONAL...
2007 Mitsubishi Fuso FE84D 16ft Dovetail Flatbed Truck (A50323)
2007 Mitsubishi...
