Diesel Truck battery Life?
   / Diesel Truck battery Life? #21
Just traded in an '05 1/2 ton Chevy with the original AC Delco battery and 93K miles. It made a lot of less than 2 mile trips between rental properties etc., no problems.
   / Diesel Truck battery Life? #23
I have been getting 12 years each out of my pickup batteries - starting with the 1986 F250. I think if the water level is kept to recommended levels and VR working properly, good battery life will follow. My 2002 Ram 3500 batteries are still original and will start the truck down to -25C / -15F - any colder than that I don't even bother going outside unless it is absolutely needed (it gets to -35C/-30F quite often around here).
I think with proper maintenance, a truck battery should give at least ten years service.
   / Diesel Truck battery Life? #24
wow.. 12 years! impressive.
i get 5 max usually.
last set i had went 7.. but I nursed them the last year..
   / Diesel Truck battery Life? #25
I'm always amazed with the info in these threads. People talking about getting 10-15 years of life out of a lead acid battery. That has definitely not been my experience with any batteries I have had.
I took my load tester to each battery today and both held the load in the good section. Truck hasnt been started in a week. I called the local gm dealer and asked for for the same AC battery and it was $120 each with a 42 month replacement warranty.
If one goes bad how do you know? will the diesel still start? I realize temperature may have an effect.
out of my three diesel trucks I have never replaced a battery 00 f250 7.3 psd 03 F350 6.0 psd 07 gmc duramax
   / Diesel Truck battery Life? #28
my wife's yukon eats a battery in 3 ys. IMHO.. they spec too small a battery for it and it's hard on it.
my diesel trucks have 2 large bats.. and like i said. i can usually get all 5ys out of a 5yr bat. my last set i actually got 7 ys.. but the 6th year, I could tell they were at about 80%.. and on the 7th year.. i could get real weak bats int he cold.. or if i didn't drive the truck a week....
   / Diesel Truck battery Life? #29
As a Ford guy, I always replace my batteries with Motorcraft from the dealer. They are about the same price as the part stores stuff.
They have told me before that they typically get more life out of the replacements than the originals.
On average, my family vehicles have been getting 7-8 years on the original. My current truck left me stranded after a dove hunt and it was only 5 years old. Luckily the nearby farmer was home and was able to jump it. Replaced the next day.
Being proactive is great but I hate dropping 100 plus bucks for something that isn't used up yet. Kinda like your alternator. You just hope when it goes out it doesn't cause a major situation. When it died on my last truck I drove the last several miles, at night, on battery alone and coasted into the driveway with a dead engine!
   / Diesel Truck battery Life? #30
a buddy and me were driving home from work, both of us have diesel trucks with 2 bats. his alt died ont he way to work. onthe way home we swapped batteries so he would have a hot set to get home.. then swapped back the next morning after putting his alt on.
2017 John Deere 9620R Scraper Special Tractor (A53342)
2017 John Deere...
UNUSED FUTURE FT-XJ7T 7 TON 46" HYD THUMB CLAMP (A51248)
UNUSED FUTURE...
2019 KOMATSU D51PX-24 CRAWLER DOZER (A51246)
2019 KOMATSU...
2019 KUBOTA U35-4 EXCAVATOR (A51246)
2019 KUBOTA U35-4...
JOHN DEERE CP 770 (A53084)
JOHN DEERE CP 770...
2009 IC Corporation PB105 School Bus (A51692)
2009 IC...
