geneP
- Joined
- Jun 28, 2000
- Messages
- 840
- Location
- Central Mississippi, USA
- Tractor
- Case-International 385, Kubota L5450 w/LA1150A loader
I looked at a 243 and am confused about the draft position for the position control to work. The owner wasn't present, so I had to feel through my inspection. When I first approached the tractor the draft and position control were opposite each other at about mid point. When I started the tractor the lift wouldn't raise. I finally moved the draft lever full back and the position control lifted and released the arms normally. I have a case-IH with draft but I never use it, I think it stays in the full forward position.
I'm thinking about buying the tractor and need to know if this is normal and how to check the operation other than making sure it lifts and holds a load. Thanks for you comments.
Gene
Gene
