No more galvanized bolts/nuts at my TSC ???
   / No more galvanized bolts/nuts at my TSC ??? #21
This may need another thread - but
Are there any mail order places that still sell by the pound?
AgriSupply seems to at $2.69/lb for all sizes,
Galvanized Hex Head Bolt 1/2 X 10
compared to Hiawatha where a SINGLE 10" cost $2.94
/edit I've got to drive from Ms to DC next week, it might be worth my while to go 60 mile out of my way to pick up a couple hundred pounds of bolts.
Looks like the AgriSupply 1/2 x 10 bolts are $2.69 ea. for a single bolt. I punched in a qty. of 10 and price was $26.90
Its still a better price than Hiawatha.
   / No more galvanized bolts/nuts at my TSC ??? #22
maybee mcmaster/carr?
   / No more galvanized bolts/nuts at my TSC ??? #23
Did you look at the column labelled "QTY" where it reads "LB"?
Item # Description Qty 1 + Order
33302
GALVANIZED HEX HEAD BOLT 1/2" X 10"
Availability: In Stock - Check Store Inventories
LB
$2.69
I think that means "POUND". Note all the GALVANIZED HEX HEAD BOLTs are $2.69. 5/8 x 2 1/2, 3/4 x 10", etc.
Nope, pkgs of 1 to 10
   / No more galvanized bolts/nuts at my TSC ??? #24
I typed 10 for qty. If that's $26.90 for 10 lb's. then how many bolts would I receive for a 10 lb. order. I think I'd be calling AgSupp to make sure if their price is per pound or per bolt. How would I know what each bolt weighs before ordering. If I needed 50 bolts for a project I'd have to know what each bolt weighed so I'd know how many lbs. to order. I think the lb. they show for qty is misleading.
   / No more galvanized bolts/nuts at my TSC ??? #25
my 1st search showed packages of 1-5-10-25. stopepd searching after that. though did not see weight packages ( per pound ).. etc.
   / No more galvanized bolts/nuts at my TSC ??? #26
Do you mean you entered the number 10 in the box labelled "Order"?
Why is their unit of measure "misleading"?
For instance I need 1/2" hex head bolts 4.5" long, going to a handy dandy web site: Bolt Weight Calculator | Portland Bolt I find that there are about 4 bolts to the pound. So for $2.69 that works out to about $0.67/bolt, or 15 bolts for $10.09 versus Home Depot, 15 bolts for $23.78 1/2 in. x 4-1/2 in. Galvanized Hex Bolt (15-Pack)-80980 at The Home Depot.
   / No more galvanized bolts/nuts at my TSC ??? #27
I'm just saying that most people who are working on a project and need to order a specific number of bolts may go to that site and enter 10 for qty. not realizing they are ordering 10 lbs. When I go to TSC or Hiawatha I buy the qty. I need. Sometimes I get charged by the lb., other times its per bolt, sometimes its by a pkg of bolts. Not everyone has a handy dandy bolt weight calculator app on their phone.
   / No more galvanized bolts/nuts at my TSC ??? #28
Well if MOST people make the mistake it must be ok.
And at the Tupelo TSC they still sell some bolts by the pound, $4.59 per lb.
I didn't check for galvanized, but at the $2/lb difference it could be worth my while going out of the short path from Ms to VA to pick up a couple boxes of bolts.
/edit at Agrisupply
   / No more galvanized bolts/nuts at my TSC ??? #29
The TSCs I frequent sell Grades 2, 5, and 8 hex head by the pound. ... At least they did last week.
Gr2 is brite galvanized
larry
larry
Grade 2 is usually zinc (or variation) plated, and will corrode in pressure treated lumber. Not the same as hot-dipped galvanized!!
Utility Trailer (A52377)
Utility Trailer...
PALLET OF SCAFFOLDING PARTS (A52706)
PALLET OF...
BUSH HOG 2615 - 15' BATWING MOWER (A51243)
BUSH HOG 2615 -...
JOHN DEERE 3032E TRACTOR (A54756)
JOHN DEERE 3032E...
Polaris Side by Side (A50324)
Polaris Side by...
JOHN DEERE 560M LOT NUMBER 15 (A53084)
JOHN DEERE 560M...
