fuel 135 with pekins desiel
   / fuel 135 with pekins desiel #1
stuart50
columbia ms
135 massey feguson
my son ran the tractor out of fuel put more fuel in it and bleed lines tractor runs fine for about 30 min and quits rebleed and insalled new lft pump still runs about 30 min and quits still getting air is it just not bleed good are what thanks for any help
   / fuel 135 with pekins desiel #2
I always had to loosed one one of the injector nuts while cranking to get mine to run. This is somewhat of a pain because I had to take the fuel tank loose and lift it to get to the injector nut.
   / fuel 135 with pekins desiel #3
I has at split my MF150 (same engine), and had to do the same as described above to get it running good again. It took several times to get all cylinders going.
   / fuel 135 with pekins desiel #4
you need to renew the fuel filters, or check them out, also check that the tank filter is OK, if need be take it off and wash it out, there also a filter on the fuel injector pump which may also need a clean.
2016 HINO 268 26FT BOX TRUCK (A51222)
2016 HINO 268 26FT...
16 STEEL SHEETS CURVED (A50854)
16 STEEL SHEETS...
1995 KOMATSU WA320-1 WHEEL LOADER (A51242)
1995 KOMATSU...
2022 ISUZU NQR 18FT FLATBED (A51222)
2022 ISUZU NQR...
2017 JOHN DEERE  30G (A50854)
2017 JOHN DEERE...
2014 KENWORTH T800 MIXER TRUCK (A50854)
2014 KENWORTH T800...
