Blind bolt options?
   / Blind bolt options? #11
Maybe that is what I was referring to? Sorry you posted while I was typing.
noprob. jjz posted the same while i was typing. ;)
so all 3 of us came up with the same idea within minutes. :)
I'm a member of a Cummins forum and someone posted the idea of the toggle bolt. I'm not sure why, but I didn't like the idea but its gaining some momentum with me. Mainly because its a cheap fix. I can't put a hole anywhere else in the pillar, the holes in the plastic handle don't really allow it to be move up or down any. The hole is about 1/2" in diameter. Thanks for the ideas.
   / Blind bolt options? #13
1/2" hole should accomodate a toggle .
the only other idea i had was to take a pipe plug and screw it into the hole. ( drill and tap the plug for correct threads first )
pipe plugs drill and tap VERY easilly. tap it for the oem fastener, grind it flat. use a seperate fastener and a spare nut to thread intot he plug and lock against it so then you can screw that into the hole., then double wrench the lock nut loose and remove the nut/bolt combo leaving you the pluged hole with no threads in the middle.
i till think a toggle may be easier..
   / Blind bolt options? #14
It appears that this may not help in your situation, but I had the same problem on an 04 1/2 ton. The insert just spun and spun. I pried the sides of the insert flange and put a vice grip on to hold the insert while loosening the bolt. I then slathered the area around the insert with JB Weld and let it set up before installing the new grab handles.
Looking back, that might have worked.
   / Blind bolt options? #16
I would try a toggle also or wedding in a stud and going to a nut on the handle end.
Chris
   / Blind bolt options? #17
well nuts. this is the first image that came up when i googled it. they come in all different sizes
Metric Well Nuts
   / Blind bolt options? #18
Try a search for thread-serts.
somewhat of a pop rivet that puts threads into holes.
   / Blind bolt options? #19
Pure genius, I tell ya! We can't all be wrong can we? :thumbsup:
2006 FREIGHTLINER COLUMBIA 120 (A55745)
2006 FREIGHTLINER...
2016 International WorkStar 7400 Cylinder Pallet Flatbed Truck (A55852)
2016 International...
Deere 35G (A53317)
Deere 35G (A53317)
2000 FORD F-350 SUPER DUTY BUCKET TRUCK (A52472)
2000 FORD F-350...
2000 John Deere 1860, 30ft Wide, Gandy Box, Wing Fold, 7.5in Spacing (A53472)
2000 John Deere...
2021 New Holland C327 Compact Track Loader (A57024)
2021 New Holland...
