no hydraulics after clutch repair
   / no hydraulics after clutch repair #1
Gary Beason
Mesquite Tx.
1972 ford 2000
Howdy,
I am a new member, and about a week ago I was trying to get info on why my tractor was positive grnd. A few responces came back at me from soundguy and more. I still haven`tgot that straightened out yet. I put a newer battery onit and wired neg. grnd. and pollerized yhe gen. like soundguy said to do, and I am getting a good reading on volt meter.
I had the tractor apart to replace the clutch`s and all the seals. Now, I have no hydraulic`s for my three point. I know it needs to be bleed, Can some one please tell me how to do that? It is a basic 2000, no frt. loader or any thing else. I have put fresh fluid and I am ready to finish it up.
Thanks, Chief1
   / no hydraulics after clutch repair #2
If the pump input port is flooded, then just operate the hyd to purge the air.
You may have to go through about 5 to 10 cycles.
Thank you so much, I moved the lever up and down 21 times before it started working. You are a life saver.
chief1
   / no hydraulics after clutch repair #4
Remove the 1/4" pipe plug on the hydraulic pump head and crank the engine without starting until oil flows from the port.
(APPROX 76) 1 1/2" X 1 1/2" X 46' TUBING (A57192)
(APPROX 76) 1 1/2"...
2016 Tesla Model S 85D Long Range AWD Sedan (A51694)
2016 Tesla Model S...
2014 MACK GU713 WATER TRUCK (A51247)
2014 MACK GU713...
NEW Woods Reverse Rotation 5ft Tiller (A55301)
NEW Woods Reverse...
UNUSED LANDHONOR LHR-EPC40 PLASMA CUTTER (A57193)
UNUSED LANDHONOR...
Kubota SVL95-2 High Flow Cab Skid Steer (A55302)
Kubota SVL95-2...
