Bush hog mower on a JD iMatch
   / Bush hog mower on a JD iMatch #1
Wooddust
Western Missouri
JD3720
I bought the iMatch for my 4730 and have it hooked up to a 6 foot bush hog. The top link articulates so you dont hang up in rolling areas mowing. But with imatch it just pops the top link hook off. I am missing something or am confused ..it happens at my age. What is the solution? ! Can do photos later if needed
   / Bush hog mower on a JD iMatch #2
is your top link on your imatch adjustable?
(new version is)
bush hog may have a kit for use with a quick coupler,
have you checked with the mower dealer?
Top link on iMatch is adjustable. I have it at highest point. I should check with Bushhog as well. Maybe someone here has had the issue?
   / Bush hog mower on a JD iMatch #6
You do not want a floating top link, you just need to set up the Bush hog for a quick hitch. Here are the different set up diagrams for each type:
View attachment 390335View attachment 390336
Bingo...I think!!.. I have contacted Bushhog and already have them on this. FYI People bash manufacturers all the time and when one hits one to of the park we should say so...I left a Facebook question to Bushhod last night at like 730pm (Saturday) By 800pm I had a response...and i think thats eastern time where they are....amazing customer service Thank you mr Deerherd
   / Bush hog mower on a JD iMatch #8
<img src="http://www.tractorbynet.com/forums/attachment.php?attachmentid=390335"/><img src="http://www.tractorbynet.com/forums/attachment.php?attachmentid=390336"/>
Why not use an adapter like I posted so the floating top link can be used?
   / Bush hog mower on a JD iMatch #9
You get your "float" from the QH pins being in the same plane. All the adapters do is convert non standard implements to the correct standard and you will just bend the yokes on your cutter using the adapter in short order. When buying any cutter, realize set up is different for a QH and let your dealer know you have/intend to use it on a QH. Good luck!
   / Bush hog mower on a JD iMatch #10
Check out pages 15-18 of the landpride link I posted.
(INOP) FORD 9N TRACTOR (A51247)
(INOP) FORD 9N...
4"x8' Treated Post, 36 Piece Bundle (A52384)
4"x8' Treated...
2021 NEW HOLLAND TS6.130 TRACTOR (A51406)
2021 NEW HOLLAND...
2018 CATERPILLAR 950GC LOADER (A51246)
2018 CATERPILLAR...
UNUSED FUTURE 19" EXCAVATOR RAKE (A51248)
UNUSED FUTURE 19"...
20' Multi Door One Way Ship Container (A52384)
20' Multi Door One...
