Opinions on this Bush Hog
   / Opinions on this Bush Hog #11
Metal looks straight. Nothing wrong with grease. Damage could have been done before grease was added, but they could have put in new seals and you would be in the same shape. I suspect that most of those bushhogs will have some pitting unless stored inside. If you need A HD unit. I doubt you will get one cheaper.
After some good insight from your responses, I think I am going with a new medium duty unit and look at something like the Everything Attachments offering. For a couple bucks more I can get a unit that is new without the potential worries you all have mentioned. Any other brands worth considering on the medium duty front?
Thanks
Steve
   / Opinions on this Bush Hog #13
EA dont make a 6' cutter that I see. And everything else is light duty.
Landpride, woods, rhino, bushhog, brown, kodiak are all pretty popular brands.
You never answered my question....what do you plan on mowing? What do you require in a cutter?
For equal money....I wouldnt take any of the cutters EA offers over a BH306
I would mostly use it to cut brush and heavy Bahia grass (1 foot +), some palmetto but I have a root grapple and plan on getting those out with that.
Was looking at this model offered by EA:
Fred Cain Agricutter for High Horsepower Tractors
Thanks for the advice.
   / Opinions on this Bush Hog #15
   / Opinions on this Bush Hog #16
Brown Mfg. makes a good mower 416 out of Dothan Al. but have dealers all over
So what should I look for when I check it out and what would be a good price on it assuming it is in good working order?
   / Opinions on this Bush Hog #19
Check with Bush Hog or a dealer to see if parts are still available for it. If you buy and the gear box grenades 6 months later, can you get parts to rebuild it? Or, even little things like blade bolts, blades, slip clutch discs, etc.
I tend to buy more recent vintage implements because I have very little free time and want to spend it working WITH my equipment, not ON it. And I don't have time to spend hours searching for parts no longer commonly available.
Now, having said that, I bought a Gannon box blade that was probably on the Ark with Noah, but there's not much to go wrong on a box blade.
As for things to look at when you see it in person:
1. Grab the input shaft to the gear box and see if there's any play in it. Then turn it to ensure that the gear box turns smoothly and doesn't make any grinding noises.
2. Look at the underside of the deck and see what it looks like. Are the blades and/or blade carrier (stump jumper / blade bar) beat up? Also, if you can see where the gearbox output shaft comes out under the deck, see if there's any oil or grime buildup, which could be a sign of a leaky seal.
3. If possible, run the cutter and see how it operates.
4. Check the gearbox oil to see if it's milky or appears to have any water in it. Smell it to see if it smells burnt.
5. See if the PTO shaft is in good shape and slides in and out smoothly. Half of the shaft doesn't have a shield on it and will need to be replaced. Also, the gearbox doesn't have a shield on it, but you can make one or have one made easily enough.
6. Look for any bends, welds or other signs of damage or abuse. Some of the side skirting looks like it's bent.
7. Check the tailwheel to make sure it turns and rotates like it should and see if the wheel bearing appears to be in good shape.
8. Look carefully at the slip clutch. You really can't tell much without adjusting it and operating it. But look to see if it appears to be rusted up or painted over (which could indicate that it's not slipping like it's supposed to). Or the slip clutch discs could be worn out, which allows the slip clutch to slip too much (and then they need to be replaced).
   / Opinions on this Bush Hog #20
As a parts manager for a Bush Hog dealer, I'll say that any part you might need for that 306 is available. Blades (756BH) and blade bolts (63607) are still used on current models (and in stock here). Aftermarket blades and tailwheel assemblies & components are out there, too.
I've never seen replacement blades for a Fred Cain cutter featured anywhere, but I admit I never had anyone ask for them. There's probably more 306's still in use than however many FC 6' cutters were ever built. Series 5 Metric drivelines are rated for 47HP @ 540 RPM.
JOHN DEERE XUV590M (A53084)
JOHN DEERE XUV590M...
2025 JOHN DEERE 408R LOT NUMBER 10 (A53084)
2025 JOHN DEERE...
Ingersoll Rand Air Compressor (A51573)
Ingersoll Rand Air...
(1) 12ft Tarter Gate (A51573)
(1) 12ft Tarter...
