3020 john deere maintainance
   / 3020 john deere maintainance #1
dvaidm
Member
Harding mn
3020 john deere and 50 john deere
Doing some maintenance on the 3020 john deere it is gas. Where is the fuel filter located at. I am going to replace the plugs and wires and cap and rotor does it have points. Any other recommendations I should do.
   / 3020 john deere maintainance #2
:welcome: to TBN
Fuel filter located right side of engine. part # AR50141 (follow fuel line from the carb).
Yes, has points.
If you go to jdparts.com, and enter model 3020, you can get to all the parts on your Deere. Makes life much easier if you have the same pics to look at and parts list as your Deere dealer when you order/buy parts.
   / 3020 john deere maintainance #3
:welcome: to TBN
Yes, has points.
The part number AR50141 is an incorrect number. Gasoline filter is AR10104 if tractor is equipped with a MS carb or AR13019 with a Zenith carb.
   / 3020 john deere maintainance #4
AR50141 is correct for serial numbers above 123,000. Earlier tractors did not have in-line filter. Only a strainer in the inlet fitting to carb.
   / 3020 john deere maintainance #5
Thanks for the correction as I was thinking about a 3020 '68 & below not '69 & above.
2003 Fleetwood 2 Axle Camper (TITLE) (A50774)
2003 Fleetwood 2...
2019 CATERPILLAR D6N LGP HI TRACK CRAWLER DOZER (A51242)
2019 CATERPILLAR...
2004 30ft S/A Scissor Pontoon Boat Trailer (A50324)
2004 30ft S/A...
Ford 8N Tractor w/3pt. Buck Saw (AS IS) (A50774)
Ford 8N Tractor...
2010 Ford F550 Service Truck (TITLE) (NOT RUNNING) (A50774)
2010 Ford F550...
2020 Hisun 750 CCEFI UTV (A50514)
2020 Hisun 750...
