Leaves of three, let it be?
   / Leaves of three, let it be? #1
KTurner
Gold Member
"Leaves of three, let it be" appears to be overly broad. There seem to be plenty of plants with leaves in groups of three that are not poison ivy. We have three leafed plants growing along the tree line that I'm fairly sure are not poison ivy, but we also have poison ivy. I'd rather not kill a bunch of plants (its mixed in with other plants I'd like to keep) or avoid parts of our land out of ignorance. Does anyone have a good guide for sorting out the different three leafed plants (mid atlantic region)? I've poked around on the Internet but the signal to noise ratio is pretty bad.
Keith
   / Leaves of three, let it be? #2
here ya go, but generally the leaves of three let them be is good. the three types can all take on different LOOKS while still being generally the bad plants. But look at Sumac there are many varieties which most are OK and the Poison type has more than 3 leaves
click the pic for full size pic.
Mark
   / Leaves of three, let it be? #3
around here, virginia creeper is the most common impostor. i let it be unless it's climbing a building or choking out a more desirable plant.
2,4-0 works great. in tight places you can paint it onto the leaves of the poison ivy, but make sure to get a large percentage of the vine, to kill it while letting the plant it's growing in live. i don't bother trying to manually remove the vines - they always come back. controlled use of herbicide is my weapon of choice. i have no mercy for the stuff but, like the OP, would rather not kill everything in sight just because poison ivy moved in.
I can recognize at least some poison ivy. But some of the information I'm seeing says that poison ivy is pretty variable. Some leaves will have the 'teeth' like in the picture Spiker posted but some will not. Sometimes its a climbing vine, sometimes it grows along the ground and sometimes its a shrub.
I think there are some tick trefoil plants and hog peanut plants mixed in there. I definitely have blackberry and raspberry plants, which often have three leaves, in there. And some virginia creeper, which normally has five but can sometimes have three leaves (when young).
Keith
   / Leaves of three, let it be? #5
I can recognize at least some poison ivy. But some of the information I'm seeing says that poison ivy is pretty variable. Some leaves will have the 'teeth' like in the picture Spiker posted but some will not. Keith
The poison ivy I see in my area looks like this:
Steve
   / Leaves of three, let it be? #6
Last time I had a bout, my eyes were swollen shut for 3 days.
I'm in the spray it all camp. Then spray again.
   / Leaves of three, let it be? #7
Steve - your pics look like our poison oak. The leaves of poison oak are a little more shiny. I'm deathly allergic to poison oak and for years I would get shots every spring. I had a small patch here but repeated applications of herbicides finally wiped it out.
   / Leaves of three, let it be? #8
we have poison ivy creeper vine , weed (as in pic above) , bush up to 5 ' tall ... the sap in the roots is more toxic than the leaves .... comes in all sizes and shapes ...
in full sun or shade ....
   / Leaves of three, let it be? #9
So true. It is important to know the leaves, and also the twigs. I have had some of my worst poison oak in the winter after the leaves dropped. The stalks/twigs can be very inconspicuos, and full of that lovely oil... :-(
   / Leaves of three, let it be? #10
I was told that the center leaf has a stem the other 2 don't... I believe that is true for all the poison ivy/oak... that is what I use and so far no ichy
UNUSED WOLVERINE CB-11-750F HYD CONCRETE BREAKER (A54757)
UNUSED WOLVERINE...
2017 Polaris 500 Ranger Diesel Utility Cart (A53421)
2017 Polaris 500...
2019 Chevrolet Silverado 3500HD 4x4 Crew Cab 10FT Flatbed Truck (A51692)
2019 Chevrolet...
2023 Country Clipper Boulevard 54in Zero Turn Commercial Mower (A52377)
2023 Country...
PEMBERTON LR129-1123 RAKE ATTACHMENT (A53426)
PEMBERTON...
KNOW BEFORE YOU BID - DO YOUR HOMEWORK AND BE HAPPY WITH YOUR PURCHASE (A52706)
KNOW BEFORE YOU...
