King kutter tiller and disc quick hitch mods
   / King kutter tiller and disc quick hitch mods #1
Blade Breaker
Gold Member
Southern MN
5115M, 825I S.E., 1445 S2, F932, M, H, 8N,
Hi,
I read a few posts and got some great info before I purchased this tiller so I thought I would let you know what I did to get it to work well with a cat 2 quick hitch. Also just picked up this disc and modified that also.
On the tiller the main hitch plates were about .5 inches to narrow so I cut one side off and moved it over. The hitch would hit the tube behind the pin so I cut the tube out between the plates and welded it back in about .5 inches set back. The top hook would hit the bolt and the braces so I removed the bolt and welded the braces to the outside of the frame. The pto shaft was short so a extension fixed that. It hooks up very nicely now and it also seams to bounce less with the extra weight of the quick hitch. Not sure why they couldn't have set it up from the factory like this?
The disc was easy. I added 2 half inch plates and then added 2 gussets welded to the main tube and these plates. I had some 1 inch grade 5 bolts that were a bit to long but work fine.
Both are very easy to hook up to now.
   / King kutter tiller and disc quick hitch mods #2
Have mentioned this before even if existing equipment has to be modify once it fits worth all the efforts when you can hook and unhook without straining and possible hurting yourself
You got that right. Not sure why these were not designed to be quick hitch ready to start with.
   / King kutter tiller and disc quick hitch mods #4
I've been running my KK2 tiller without the lower bushings. The QH hooks won't clear the frame with them on, but will without the bushings.
One day I intend to modify the frame for an extra 1/2" of clearance so the bushings will fit... One day...
Skid Steer Plate Attachment (A50322)
Skid Steer Plate...
BUSH HOG BH114 4' ROTARY MOWER (A51243)
BUSH HOG BH114 4'...
2013 Chevrolet Caprice Sedan (A50324)
2013 Chevrolet...
2014 Ford F-550 4x4 Ext. Cab Auto Crane 6406H 6,000LB Crane Service Truck (A50323)
2014 Ford F-550...
2016 CATERPILLAR 325FL EXCAVATOR (A51242)
2016 CATERPILLAR...
VERMEER RTX130 WALK BEHIND TRENCHER (A51242)
VERMEER RTX130...
