Changing a gas motor to electric on a mortar mixer
   / Changing a gas motor to electric on a mortar mixer #1
mx842
Richmond Va
Kubota L3301, PowerKing 2414, John Deere 316, Gravely ZT HD 52
I just came across an old mortar mixer cheap but it doesn't have an engine on it. I was wondering if I could convert it over to an electric motor. I have a 5Hp electric motor I could use. The only problem is that the motor is 3 phase which I don't have but was thinking about building a phase converter out of another electric motor I have to run the mixer motor.
I know it sounds like a lot of trouble to do this but I have these electric motors and I don't have a gas motor with gear reduction on it. I was just wondering if anyone else has ever done this before and if so how did you gear the electric motor and in the end how did it work out?
   / Changing a gas motor to electric on a mortar mixer #2
should work, the three phase motor on a static converter is about 2/3'S of plate rated power.
the static converter energies the third winding to act like a starter winding and then the motor runs on the other two windings,
I ran a lot of shop tools on static and rotary converters until I got three phase,
since the mixer should not need to be started under load, the static converter should work, if you plan on starting it under load then a rotary converter should be used, (the converter needs to sized to the motor ran,
Yeah, that's what I was planing and hopefully once I get it spinning the paddles it will keep going until the batch is done then shut off, clean out then start over. I need to check what the motor RPM's are to see how much I need to slow it down or speed it up. I guess I can do that with pulley size to make my own gear reduction.
I guess I could do that with a gas motor too but everybody I have talked to says I have to have a engine with a gear reduction drive on it to get it to work right.
   / Changing a gas motor to electric on a mortar mixer #4
You could even make it reversing so the internal paddles push the mix out.
   / Changing a gas motor to electric on a mortar mixer #5
Yes that is an option of-course but I hate to buy a new engine for something like this. I already have the 2 motors so why not use them. Have you tried to sell anything like that these days. I had these and a bunch of other stuff on Chaig's list for months and all I got was ten thousand calls from people that wanted to do me a favor and take them off my hands so I didn't have to haul them to the dump. On top of that I got my account high jacked and before it was all over I ended up with to viruses and almost lost my whole computer. In the past I have sold and bought a lot of stuff on there but it's gotten really bad with all the scams people run on there.
I'm not saying I never would buy one of those motors on it I would rather use what I have.
   / Changing a gas motor to electric on a mortar mixer #7
"...Have you tried to sell anything like that these days. I had these and a bunch of other stuff on Chaig's list for months and all I got was ten thousand calls from people that wanted to do me a favor and take them off my hands so I didn't have to haul them to the dump. On top of that I got my account high jacked and before it was all over I ended up with to viruses and almost lost my whole computer...."
sorry.
   / Changing a gas motor to electric on a mortar mixer #8
I recently got a 10 horse 3ph 230 1750 motor running on 1ph. I used a total of 220 uf run caps and 900 uf start caps from one hot leg to the open leg. The start caps are hooked thru a potential relay (6X560). Grainger has it on clearance sale. It takes about a second to reach full speed and runs smooth and quiet. With a 5 horse motor you only need half the caps. I bought the run caps at Surplus Center.
It's running a large car alternator that I'm using as a dc welder. Works very well.
   / Changing a gas motor to electric on a mortar mixer #10
Why not make it PTO powered and run it off your tractor?
New Kivel 3500 lb. Skidloader Forks (A50775)
New Kivel 3500 lb...
2016 Peterbilt 567 Tri-Axle Dump Truck (A51692)
2016 Peterbilt 567...
1985 Miller Wildcat 350-D Welder (A51691)
1985 Miller...
2015 Ford F450 SD Flatbed (A52377)
2015 Ford F450 SD...
2013 Vermeer V800G T/A Towable Vacuum Trailer (A55787)
2013 Vermeer V800G...
2015 JOHN DEERE GATOR TURF UTV (A51406)
2015 JOHN DEERE...
