Need 1000 CCW PTO snowblower. 84"
   / Need 1000 CCW PTO snowblower. 84" #1
Phallstedt
Northport, mi
Deutz F100 Agcompact
I have a Deutz front pto but it turns in CCW rotation at 1000rpm. Need a snowblower around 84" width. The only model which I can find it a Trejon Optimal in Sweden but there are no dealers here. What other companies make a snowblower to fit my deutz?
   / Need 1000 CCW PTO snowblower. 84" #2
Erskine's front-mounted rear drive blowers are built "mirror image" - they turn CCW. They have a chainbox and shaft but I guess the head could be adapted for the Deutz front pto. They are rugged and work fine at rpms above 540 - I often run mine at 750. The Deutz probably makes enough power for snow blowing with pto at 750. Erskine FMs are made up to 8' wide. Mine was 6' but is now stretched to 86" .
   / Need 1000 CCW PTO snowblower. 84" #3
First question,
Do you have the three poinjt hitch mount in front already??? It does not sound like it.
What you can do is purchase a front three point hitch kit with a PTO Adapterkit that attaches to the flywheel.
Are you not alt all interested in a rear mount? A rear mount would cost you 60%+ less money.
   / Need 1000 CCW PTO snowblower. 84" #4
Erskine's front-mounted rear drive blowers are built "mirror image" - they turn CCW. They have a chainbox and shaft but I guess the head could be adapted for the Deutz front pto. They are rugged and work fine at rpms above 540 - I often run mine at 750. The Deutz probably makes enough power for snow blowing with pto at 750. Erskine FMs are made up to 8' wide. Mine was 6' but is now stretched to 86" [/URL].
From your link:
I'm just a snowblower nut - I've had all kinds but lately I'm interested in front ones. My tractor has no mid pto - so the Erskine setup does the trick. It spins opposite from other blower heads - the drive shaft runs from the back - and is reversed. That limits the options for a front blower to an Erskine. Thing is, above 78" their blowers are too huge. So I'm making my own.
"Nut" is right. That's the craziest thing I've seen in a long time. Power to ya though...I would've added 6" wings and called it a day (which I bet would do the same job), BUT I've always been a fan of over-engineering and excessive fabrication... 'just for the h-ll of it'!!
   / Need 1000 CCW PTO snowblower. 84" #5
The original plan was for 9" wings, but the auger sprocket is pretty big on these. Besides, destroying it first was more fun. I do need snow blower counseling - proof here.
   / Need 1000 CCW PTO snowblower. 84" #6
OK - that is actually brilliant. And yes, I do dig the concept of "destroying it first" being more fun.
2003 Ford E-450 16ft Reefer Box Truck (A55788)
2003 Ford E-450...
2019 FREIGHTLINER M2 106 REFRIGERATED TRUCK (A52706)
2019 FREIGHTLINER...
2012 Mack CXU613 Day Cab T/A Wet Kit Truck Tractor (A55788)
2012 Mack CXU613...
Kubota M4700 4WD 51HP Utility Loader Tractor (A55787)
Kubota M4700 4WD...
METAL SHOP TABLE W/CONTENTS (A55745)
METAL SHOP TABLE...
ATTENTION PLEASE READ (A53314)
ATTENTION PLEASE...
