The loader is impressive. Strong lifter, with piranha bar it is a real digger, can fill the bucket every trip in heavy clay. I just excavated two feet of dirt for a barn floor. And I dug out stumps with it on some large stumps. there were no rocks and this thing really was able to tear into a stump digging down on each side and then in front letting the piranha bar chop the roots by easing into the area under the stump repeatedly and after the bucket has cut to depth of bucket just lift and push on top of stump and over it goes. Surprise surprise. Blew my neighbors away and the Yanmar is becoming the talk of the neighbor hood.
I have done a several acres o bush hogging and this thing really handles a 6 footer easily in heavy grass, brush and everything in between using 6 foot deck. I would not hesitate to hook to a 7 footer.
I can just reach the 3 pt lever when hooking up but that will be easier when I mod the lever to be about 6" longer.
Having the tank in rear is OK since if it is not there it has to be somewhere. That spot works well since I spend a lot of time among bushes so am glad it is now down low and it is easier to fill on rear than it would be up front with loader.
This tractor is very fuel efficient when doing utility work, dragging a tree here, digging a hole there, making trips to the burn pile then tearing into another dirt mound where you need alternately something strong and then a lighter tractor would do. I chalk this up to direct injection in combo with turbo.
I have not found the placement of the tank to be visibility problem, that would depend on what I was doing though.
This is an awesome quality built tractor. Just make sure it is what you need.
Thank you for this. How does the power reverser work? Don't you still need to clutch to change gears or do you have to be in the low gear to start with and it just kicks you to neutral and then reverse? Are there any gears/ranges it won't work in?
A big chunk of my tractor use is in and around bush and trees so I have just assumed I'd always need to make up a skid plate to suit whatever tractor I buy. Which makes me wonder, does anyone do skid plates guaranteed to fit various models?
