Our soil is clay or clay and rock depending on the location. Some places are full of rock but others are all clay. In winter when it gets wet, I don't run the tractor in many areas because I will just make a real mess as the tractor ruts up the clay. Go into the same areas on the summer and there are no problems.
Our driveway is about 500 feet long to the house, including the turning circle. There is a big parking area and driveway extension back to the barn that is another 100'x 36'. ALL of our gravel is put on top of geotextile fabric. I used a mesh fabric instead of a woven. I can't remember WHY I used mesh but I had to have a reason. :shocked::laughing:
When I built the driveway we still had to build the house so I only put down the fabric and 3-4 inches of ABC gravel. I figured the driveway would get torn up by the construction traffic and we would add gravel after the house was built. Well that was a decade ago and we still have not added gravel. :thumbsup: We NEED some gravel to raise up the driveway above grade in a few places to keep water off the gravel. But it is not an issue that has caused us to spend money on rock.
Whatever you do, don't try to clean up all of the rocks, roots, etc out of the driveway path. I made a few passes before I realized that one, I was not going to get a clean path, and two, I was just digging a bathtub for the driveway to sit in.
I only went down 1-2 inches in a couple of passes but it was enough to require us to add more rock to get the driveway above grade. Just put down the fabric as best you can and lay down the rock....
The second phase of the driveway, the 100'x36' section, is just perfect. I did not dig down with the box blade, I just picked up whatever rocks and sticks I could an put down the fabric. That section is in great shape.
All of the sections are on a slope so they do get a bit of water in spite of ditches. The section with the "bathtub" is the problem area because I cannot ditch because of trees. The only thing I can do is add more gravel to keep the water off the driveway. Even with this limitation, the driveway is mostly fin. There is some run off that has exposed some of the fabric where the slope is acting like a ditch. We have two pot holes where water collects at the hump over the culvert. Again, we just need to add some more gravel which was the plan a decade ago but we always have better use for the money than gravel.
With our soil, there is no way I would build a driveway without fabric. My neighbors don't and they have to regrade every few years. I don't.
Later,
Dan
