FEL Snow blades
   / FEL Snow blades #11
I spoke to Hiniker's engineer about the snugness issue which is a problem on all tractor loaders due to visibility and some skid loaders. He clearly understood the problem and how a taper on the sides and bottom play would allow easier attaching. Anyway, the engineer told me about a feature they once included, that their sales guys (who apparently have never used the product) said wasn't necessary that made it a little easier to hook up the quick attach and so I looked up the inexpensive guys I bought my plow from who publish a price list to order the now-not-included-feature (little feet that hold up the quick detach plate on the plow).
http://www.bigrigtruck.net/images/bigrig/HINIKER Big Ox Snow Plow 2013-2014 Price List.pdf
In my case, I ordered from Big Red Truck, a Hiniker dealer, and picked up the plow from Hiniker's Will Call desk in North Mankato, since Hiniker is localish from my city house.
   / FEL Snow blades #12
I find my FEL works fine just by itself. Drop it leveled in float mode, and use the backblade angled and I can clear up to 8 r 9 inches just running forward through it. More than that and I'd have to start herringboning the snow off the sides of the drive since the tractor only weighs 3500# with the tires filled.
   / FEL Snow blades #13
I like the HLA product line of plows. They angle their cylinders and make a very compact plow. The greater distance between the quick attach plate and plow face the greater your turning radius is and more likely the front end of your tractor will be pushed around.
They are also a true plow that rolls snow off the blade and come standard with a crossover relief valve. Lastly they all have lateral float that follows the contours of the drive. The orange one on my old Kioti is a 2000 series and the yellow one is a 3000 series on my current LS. I think the 2000 would be all you would need. Have fun and don't wait too long, winter's coming!
How much did the HLA 3000 cost you?
John Deere Quick Attach Pallet Forks (A50514)
John Deere Quick...
CFG MH12RX Mini Excavator (A49461)
CFG MH12RX Mini...
1993 Mono Dump Trailer (A50514)
1993 Mono Dump...
2019 Ford Fusion SEL Sedan (A50324)
2019 Ford Fusion...
2016 Toro Groundsmaster 3505D 72in Rotary Mower (A48082)
2016 Toro...
2020 KUBOTA RTV X1100C UTV (A51406)
2020 KUBOTA RTV...
