L-35 Kubota hand gas lever question..
   / L-35 Kubota hand gas lever question.. #1
mrbruce
NY
L-3400---- L-35......
Just bought a 96 L-35 Kubota, and need to know about the hand gas lever at the right side rear of the seat.
Seems like it should stay in one place while your running at what ever RPM, but it don't..
It don't seem to do anything different than the foot feed does, it just returns when you let off of it...
Any ideas ??
Thanks for your time.....
   / L-35 Kubota hand gas lever question.. #2
Should stay where you put it the tension device is in need of adjustment or repair
Yes, it sure seems to need that.
Not sure how that works, but I'll remove it and check it out..
Thanks...
   / L-35 Kubota hand gas lever question.. #4
Thanks...
Try to adjust 080/090.
  • Kubota_L35_Tractor_Illustrated_Master_Parts_List_Manual.pdf
Thanks for that, the8080, I'll see what I can do with it...
   / L-35 Kubota hand gas lever question.. #6
It should hold position and needs adjusting.
If you have a backhoe attachment make sure to lube the hand levers that release the backhoe attachment. It seems common that they rust up in time.
Also check the front axle gear oil.
Thanks for the info, no BH on the L-35, but the hardware is there to hook it to.
The L3400 has one and thats enough for me...
2013 MACK ELITE LEU 633 GARBAGE TRUCK (A51406)
2013 MACK ELITE...
2018 Mazda CX-5 SUV (A51694)
2018 Mazda CX-5...
UNUSED RAYTREE RMBD72S-72' DRUM MULCHER (A51248)
UNUSED RAYTREE...
UNUSED CFG INDUSTRIAL EXCAVATOR ATTACHMENT SET (A51248)
UNUSED CFG...
2015 Ram 4500 Utility Truck, VIN # 3C7WRKAJ9FG707673 (A51572)
2015 Ram 4500...
1993 INTERNATIONAL 9700 TANDEM AXLE CAB OVER (A52577)
1993 INTERNATIONAL...
