My new Kubota with Air ride seat
   / My new Kubota with Air ride seat #71
Also looking fort a way to survive my back surgery on my B3030 with cab. It really knocks me around even with soft turf tires. I installed an aftermarket seat that has a shock absorber mount but this is still not very forgiving over rough terrain. I知 wondering if an air ride will fit in this tight enclosure or will I have to trade the tractor in for something more comfortable. I spend a lot of time mowing my 5 acres here in Kentucky.
   / My new Kubota with Air ride seat #72
Have you taken measurements and checked their catalog?
   / My new Kubota with Air ride seat #73
Find and locate and talk to a small Grammar distributor with the time to help you. Share your problem with them. They can show you how to change out foam, different densities and thicknesses of foam inserts that will allow you to taler an air seat to your needs.
   / My new Kubota with Air ride seat #74
I’m squeezing the MSG93 series seat in now, had to custom drill 2 front mounting holes and weld mounting tabs for the rear base attachments, Its been a really tight fit and the seat arrived with no instructions or hardware. I’m checking with the supplier about this since an expensive seat option like this should at least have mounting instructions.
   / My new Kubota with Air ride seat #75
Seats are pretty simple, bolt them in and hook up the power. My tractor was pre-wired for the air ride seat option so I just had to plug the wires together. The hardest part of your installation is the modifications you already made to the base.
   / My new Kubota with Air ride seat #76
   / My new Kubota with Air ride seat #77
For those with the B3030, the MSG93 seat base was configured with mounting holes that only aligned with the front two holes already in seat floor of the tractor. There was absolutely no way to access the rear of the seat base for bolt installation. I was going to weld mounting tabs to catch the base’s exterior but found the underside of the tractor had foam glued onto the metal area directly under the seat..so..no welding and no fire. I used self tapping screws to mount the tabs to the floor.
The seat track was then mounted and found to still be too far forward when pushed all the way back (not enough leg room). The seat to sliding track interface had to be changed from the original bolt holes to position the seat assembly further to the rear on the slides. Guess what? No bolt holes in the slides so self tapping screws had to be used for the new holes.
The seat is not a simple bolt on for any of those who wish to install the MSG93. It takes patience and play (oh yeah, did I mention the self tapping screws - but drill a small pilot hole for these things to help get them started - and a nice impact drill).
The seat is more comfortable than the mechanical shock variety that I had installed 2 years ago. Vertical motion is well damped. Be aware the the lateral (side to side) bouncing is still quite prevalent with the air cushion providing little comfort.
I’m going to get the armrests ordered now that it appears there is room for these.
   / My new Kubota with Air ride seat #78
The size of the tractor definitely effects how much and air ride seat will help, with stock suspension seats, our M8540 is much more comfortable than the L5740 and close to the Grammar. I bought an air ride seat for the M8540 and it's still sitting in the shed, we will get around to installing this winter I imagine.
2016 Ford Fusion SE Sedan (A55853)
2016 Ford Fusion...
Honda EU3000is Gasoline Companion Inverter Generators (A55851)
Honda EU3000is...
Enclosed Service Truck (A55788)
Enclosed Service...
KSI Conveyor (A55301)
Toro Cart Run and Drive (A50324)
Toro Cart Run and...
golf cart (A55758)
golf cart (A55758)
