failure elevators new holland m100
   / failure elevators new holland m100 #1
barbutet
spain
m100
hi,
from the command post, levers raise and lower the elevador.si it does from the outside buttons work.
We have revised the potentiometer, and appears to be ok
Error 24 appears.
As can be removed?
We tested a method other tractors, but do not know exactly what to do. think it must be something to synchronize or calibrate correctly.
Thanks for your help
   / failure elevators new holland m100 #2
Sounds like you are talking about the three point hitch.
Your operator manual will show how to reset the error code
   / failure elevators new holland m100 #3
Error 24 In New Holland's electronic world means the device needs to be calibrated. If you replaced a potentiometer, it surely needs to be calibrated.
thank's, but, how can i do it?
2006 TerraGator 8104 (A55302)
2006 TerraGator...
2003 Walk-Behind Automatic Seed Spreader (A51691)
2003 Walk-Behind...
2008 Dodge Avenger Sedan (A53424)
2008 Dodge Avenger...
TANK MANIFOLD (A55745)
2011 Toyota Corolla (A55758)
2011 Toyota...
