Mahindra: Is this what I have to look forward to?
   / Mahindra: Is this what I have to look forward to? #11
Dave, do you know if the 3016 replacements will still be made by Mitsu or are they going the way of the max/emax and coming from Korea?
   / Mahindra: Is this what I have to look forward to? #12
Still Mitsu, still built in Japan, but Mahindra will supply the engines. Max is still built by Mitsu, eMax comes from Korea.
   / Mahindra: Is this what I have to look forward to? #13
Mahindra makes engines? I thought all the engines for all their models were made by others.
Good to hear about Mitsu.
   / Mahindra: Is this what I have to look forward to? #14
My 4035 has a Mahindra built engine. Although, from my understanding it is a Perkins design.
   / Mahindra: Is this what I have to look forward to? #15
Mahindra probably makes the engines for the vast majority of the tractors they sell worldwide. In the USA we sell a lot of the smaller units, hence we see Mitsu engines often and some Korean sourced engines in some models. Then again, the USA probably accounts for only 10% (rough estimate) of Mahindra's worldwide sales. This is truly an international company. Mahindra must make nearly 200k engines per year....so yes, Mahindra makes engines. Mahindra also builds airplanes, most people do not know that, although most folks know they build cars and trucks.
Mahindra spent a bunch of millions developing a Tier IV engine that does not need or use a DPF. Pretty slick, common rail and a DOC, but no DPF. Therefor no burn off cycle, etc. Also, all of the Mahindra engines of which I am aware are wet sleeve industrial type engines. If you ever need to rebuild, you can slip new cylinders in the block in-frame and new pistons etc and you are good to go. A cylinder that is cast into the block like most smaller engines requires engine removal, boring, etc. Not a big deal at the compact tractor level as people generally never put on enough hours to wear out an engine, but it is a positive point. We have had a few big old IH or JD tractors in the shop with a ton of hours needing rebuilding and it is pretty cool to just slip in new cylinders and pistons and off you go. Well, it's a little more complicated then that, but you get the idea. The Mahindra Tier IV engines are the same way.
   / Mahindra: Is this what I have to look forward to? #16
neat ! Thanks for the updates.
New Long Forks (A53002)
New Long Forks...
2009 Pontiac G6 Passenger Car (A51694)
2009 Pontiac G6...
Electric Forklift Pallet (A50322)
Electric Forklift...
2013 INTERNATIONAL 7500 SBA 6X4 DUMP TRUCK (A51406)
2013 INTERNATIONAL...
Chery 7' 35 Drawer Workbench (A50120)
Chery 7' 35 Drawer...
