1966 jd 4020 drains batteries while running.
   / 1966 jd 4020 drains batteries while running. #1
mtbargers
shelbyville tn
john deere 4020
New owner 1966 jd 4020. 24v to 12v conversion previously. New alternator, batteries check good. Start with full charge and batteries quickly discharge while tractor runs. Any ideas?
   / 1966 jd 4020 drains batteries while running. #2
Remove battery ground cable from frame and insert a test light in it's place. Light should burn if there's a drain then start disconnecting things until light goes out. When light goes out you've found the drain .
   / 1966 jd 4020 drains batteries while running. #3
DO batteries stay charged while not running? Do you still have 2, 12 volt batteries? How are the battery cables connected? DOes the charge indicator light on the dash work? If you can post a picture of batteries and cable connections, we can check to be sure all is connected properly. Also picture of alternator wiring would be helpful.
DO batteries stay charged while not running? Do you still have 2, 12 volt batteries? How are the battery cables connected? DOes tbatteries and cable connections, we can check to be sure all is connected properly. Also picture of alternator wiring would be helpful.
Not sure about discharge while not running, having to put on charger after running. Batteries in parallel pos to pos to pos post on starter. One wire alternator connected to pos post on starter. With all cables connected at starter, no short to ground at pos post on starter. Reading 14 volts at starter connection.
   / 1966 jd 4020 drains batteries while running. #5
When you state "batteries are good" did you have batteries "load tested" to be sure they don't have a dead cell?
Yes batteries load tested. Starts immediately with full charge. Is it possible that alternator discharging instead of charging batteries. Hard to believe large enough drain that alternator can't keep up.
Thanks for your suggestion.
   / 1966 jd 4020 drains batteries while running. #8
Checking alternator charging output is a simple task using a VOM.
   / 1966 jd 4020 drains batteries while running. #9
Sorry to be a little late to the game. I have a Case 850D Dozer and it was doing the same thing. One of the batteries was bad. Ran all day long, went to crank it the next morning-nothing. Got it fired off, metered all charge system components and they checked fine. Disconnected all cables at batteries. One battery metered 12.6V and was down to around 9V a few hours later.
Pelican Statue (A53316)
Pelican Statue...
12' Aerator (A53314)
2013 FREIGHTLINER CASCADIA (A55745)
2013 FREIGHTLINER...
12ft Shipping Container (A54865)
12ft Shipping...
2019 ALLMAND NIGHT-LIFE V SERIES LIGHT PLANT (A52706)
2019 ALLMAND...
NEW HOLLAND 706 30 INCH 3PT DIRT SCOOP (A55301)
NEW HOLLAND 706 30...
