5065E seat bolts work loose
   / 5065E seat bolts work loose #1
crowbar032
Gold Member
Moores Hill, Indiana
MF 150, TO-35, John Deere 5065E, Caterpiller 953 track loader, NH LS170 Skid Steer
I'm having trouble keeping the bolts that hold the seat on the tractor tight. There are only two bolts, I guess the movement side to side just wiggles them loose. The front one seems to come loose faster than the rear one. There isn't a lock washer on them, but I'm not sure it would to any good. I'm going to use a crapton of locktite and really torque them down if no one has any ideas or it's just my tractor with the issue. I guess another alternative would be replace with a stud and put a lock washer and nut on the top.
I've re-tightened them a dozen times. Anyone else have this issue? Correction or fix for it?
   / 5065E seat bolts work loose #2
My suggestion is to put some Loctite on them and see how that works.
   / 5065E seat bolts work loose #3
Ditto on the Loctite
   / 5065E seat bolts work loose #4
crowbar,
I would suggest using lock washers AND some type of thread lock on them. ( Such as locktite ) Let the thread lock set up for at least a couple hours, then ROCK AND ROLL. :2cents:
Dave
Well it appears that the threads have stripped. I'm going to try one of those coil inserts.
2005 INTERNATIONAL 9400I TANDEM AXLE SLEEPER TRUCK (A54313)
2005 INTERNATIONAL...
2015 Eager Beaver 15HBB-PT T/A Flatbed Equipment Trailer (A50322)
2015 Eager Beaver...
UNUSED Grey Waterproof PE Tarpaulin w/Grommets (A53117)
UNUSED Grey...
2004 CATERPILLAR D6R XL CRAWLER DOZER (A51406)
2004 CATERPILLAR...
2017 Takeuchi TL8 (A47477)
2017 Takeuchi TL8...
2017 Freightliner M2 106 TMA Attenuator Truck (A52377)
2017 Freightliner...
