Ford 2600 steering sector seal leak
   / Ford 2600 steering sector seal leak #1
R Barger
Gold Member
Gate City, Va
YANMAR YM336D/W Loader JOHN DEERE 850/ W Loader 2WD&4WD Kubota RTV 900
I posted this once before with no response. I need to replace the steering sector seals and would like to know if they can be replaced without removing the steering box. Reading the repair manual it's not real clear.
   / Ford 2600 steering sector seal leak #2
is this a power box?
The tractor has power steering but the leak is in main gear box not the power valve. It's just like the manual gear box and uses 90w oil in it.
   / Ford 2600 steering sector seal leak #4
I'm quite familiar with the layout of the box, I asked because a straight manual box I easier to remove than a power box, and that was part of the question asked, you can handle it from here.
   / Ford 2600 steering sector seal leak #5
Yes you can replace those seals without removing the shafts.
Just dig the old ones out with a screwdriver, etc then find a piece of pipe or conduit, etc the right size and tap the new ones in.
EZ.
EZ.
Thanks, that confirmed what I thought.
CAT FORKS W/ QUICK COUPLER (A52472)
CAT FORKS W/ QUICK...
2016 Ford Explorer AWD SUV (A50324)
2016 Ford Explorer...
2017 FORD F150 REG CAB LONG BED 4X4 (A52577)
2017 FORD F150 REG...
2014 Dodge Ram 5500 4x4 Bucket Truck with Altec AT40M - 45FT Boom, Jib Winch and Utility Bed (A52748)
2014 Dodge Ram...
J and L Cargo Express Shadowmaster Enclosed Trailer (A52748)
J and L Cargo...
2002 FREIGHTLINER FL70 DUMP TRUCK (A51406)
2002 FREIGHTLINER...
