ASV RC-100 With Loftness Head Overheating Problem
   / ASV RC-100 With Loftness Head Overheating Problem #1
Southern Forestry
Southern, USA
ASV RC-100
Ok guys, new here, just joined. I have been looking for but I am not too good at searching the internet/forums for stuff.
I recenlty bought a '06 ASV RC-100 with a Loftness 63 CCH Carbide Cutter Mulching Head.
My day goes like this. First thing in the morning, I can run for about 2-3 hrs before Temps get up (220) then I have to turn off the Head, I don't have to shut the engine down, just turn off the head and let it set for about 5-10 minutes, then it will cool down and run for about 45 minutes before it gets too hot again, then repeat. all day. I cleaned the radiator out and the air filter, etc... and keep them clean.
My questions are
1. What ISO/ or viscosity Hyd. fluid shoudl i run in this machine to try to combat the over heating?
2. What can I do to reduce the over heating hyd. fluid?
I think the hydraulic fluid is transferring the heat to my water and that's causing the high engine temps. because as soon as I shut the head down the temps drop back to 195. There has to be a way to combat this other than the $5 external oil cooler??????
Please guys, any help you can give me would be appreciated greatly.
Again I am new here and look forward to getting/giving help and just shooting the breeze with you guys.
   / ASV RC-100 With Loftness Head Overheating Problem #2
My questions are
How hot is the case drain line getting coming off the head?
   / ASV RC-100 With Loftness Head Overheating Problem #3
Try the following in order.
1. How are you cleaning the radiator? Need to remove from machine and pressure wash with high psi
2. Check hyd filters.
3. Replace hydraulic fluid, not sure type, check local dealer or someone here may know.
4. Check, I highly recommend replacing hoses from machine to head. If they are ever crimped they will stay crimped which causes a pinch point that will create heat. Make sure all your belts are tight.
5. Lastly if none of the about works an additional cooler may be needed. Hyd temp over 180 degrees is a runaway, you will not be able to control. It needs to stay under 175 to control the hyd temp. The radiators made together hurts you in this area. One side will saturate into the other, engine temp wants to run 180-190 adding heat to the hyd side.
Thanks Robbie,
I did remove from machine and pressured washed radiator.
All new Hyd Filters and Fluid (AW32)
Brand new hoses from machine to head
I am leaning towards the external cooler....but all I find are around the $4k mark...anybody know of some external coolers.
If I gotta pay $4 for one I just gotta do it, but dam
   / ASV RC-100 With Loftness Head Overheating Problem #5
Try WW Grainger. Get yourself an external cooler for stationary power units and mount that on the return line. Not very expensive.
   / ASV RC-100 With Loftness Head Overheating Problem #6
I had these problems with my RC100 as regards to over heating. Tree sap and dust is a real BAD combination. The best solution is to remove the radiator and cooler and have it acid washed. A PIA I know but it works. Regards to hydraulic oil, 32 grade is the go but it must be suitable for hydraulic motors. I ran Castrol AWH32 not Castrol AWS 32.
Hope this helps
Thanks guys for the responses.
Tonyoz, i did acid wash it when i had it out. I pressured washed it again yesterday, changed out the air filter. Both were "kinda" dirty. I think it is just going to be a constant battle to keep it clean and running cool.
Thanks guys!
   / ASV RC-100 With Loftness Head Overheating Problem #8
I took a peak on Grainger and that might be a cost effective solution. You only need to help the factory cooler, not handle the total flow. Just tee into the line going into the cooler and return into the line coming out. Between the limb risers is a good mounting spot and you will have to fab that with guard. I recommend a 12v version with lower amp draw. The electrical system on the ASV is not the strongest. Make sure you keep the alt belt tight. There is a picture on here some where of one mounted just like I suggested but I cant find it. On the cooler they are rated in BTU's removed, get the biggest you can afford, on these machine there is not a real chance of "over cooling", some even had a built in temp switch to control the fan on/off.
I found the thread you are referring to "Pics of New RC-100" but the pictures are no longer there.
I will probably do the Grainger, I have found several that woudl probably work....relatively cheap...relatively
   / ASV RC-100 With Loftness Head Overheating Problem #10
Aw 32 is pretty light oil. In south fla we run aw 68. In one machine we run aw 46 but that is lightest we use. In one of our Supertrack machines we run rotella 15-40. It's been that way for 10 plus years.
2013 MACK ELITE LEU 633 GARBAGE TRUCK (A51406)
2013 MACK ELITE...
2022 Quick Attach Brush Buster - Heavy-Duty Skid Steer Cutter for Brush and Overgrowth (A53473)
2022 Quick Attach...
2025 K2223 UNUSED Double Garage Metal Shed (A53117)
2025 K2223 UNUSED...
2015 FREIGHTLINER SPRINTER VAN (A52576)
2015 FREIGHTLINER...
2006 Kobelco SK210LC Hydraulic Excavator (A52377)
2006 Kobelco...
