ASV RC-100 With Loftness Head Overheating Problem
   / ASV RC-100 With Loftness Head Overheating Problem
I have checked the machine, I stalled the head and turned on the high flow. The gauge was reading steady at 3300-3400. I don't really know how to check the head, to ensure it is functioning correctly...any idea on how to do that.
Also, I don't know, because i have not run any other mulcher, but i feel like this machine i have is under performing. I don't know if it really is or not, but i feel it should do more.
   / ASV RC-100 With Loftness Head Overheating Problem #22
In the old days about 15 years ago when Bobcat went to a 40 gpm machine and didn't upgrade the hydraulics and cooling system, the machines overheated in 20 minutes. It was a short lived experiment.
It sounds to me like there is a stricture in the hydraulic system or in the cooling system. A plugged radiator may not be visible from the top side.. could be plugged down deep or the coolant could have broken down and/or debris could be blocking it.
An inadequate cooling fan could also be the culprit. If the cooling fan is temp controlled or isn't spinning at enough RPM's, that can do it too. CAT C series machines had a variable speed fan and some were shipped from the factory at too low of a speed to handle high flow.
I would also check to make sure your machine is actually getting into high flow. Check coolant levels, filter, charge filter, etc. Broken down hydraulic oil and water in the system can cause issues as well as air.
Usually, though, it points to the cooling system but at the same time, a restriction in a hydraulic fitting can cause excessive heat but if it's the engine overheating and not the hydraulic oil, then it is probably a cooling issue whether it's a motor problem (head gasket) or just broken down cooling system or something simple like a fan not spinning at optimum rpm.
In the old days on Bobcat, a belt and engine rpm turned the fan. Now they kick on with heat. Is the ASV belt or hydraulic drive fan?
Ok, I have a production question for you guys...how much/how many acres of land can you clear per hour? assuming it's 3"-4" privet about 10' tall mainly and some small trees (nothing over 5") intermediately scattered out within? I'm thinking/running about 1 acre per hour and half, depending on the finish product, and this is getting it clean enough to bushhog behind me once it starts to regrow. What kind of production are you guys getting? this will help me have a comparison of what i am doing versus what i should be doing.
Thanks guys, I appreciate the respones
   / ASV RC-100 With Loftness Head Overheating Problem #24
You will need to post some pics. If it's dense 3-4" privet, not scattered clusters, your production sounds really good. We don't get a lot of privet jobs around here, mostly hardwoods.
   / ASV RC-100 With Loftness Head Overheating Problem #25
Chronic problem. Since the AC system kept failing I doubled up the fan & alternator belts, it helped a little. My theory was a single belt gets loose when hot causing fan & alternator to slip. Overheats with brush mower in addition to Loftness. Don't need AC in Buffalo NY.
Year: 2018 Make: Hino Model: 155 Vehicle Type: Truck Mileage: 48,249 Plate: Body Type: COE Trim (A51692)
Year: 2018 Make...
Oil Well Pump Jack with Motor (A52377)
Oil Well Pump Jack...
2025 SDLANCH SDLGC80 UNUSED Electric Golf Cart (A53117)
2025 SDLANCH...
UNUSED FUTURE BC72 - 72" HYD BLOCK CRUSHER (A51248)
UNUSED FUTURE BC72...
2019 Allmand Night-Lite V-Series S/A Towable Light Tower (A52377)
2019 Allmand...
Knapheide Mechanics Body (A52384)
Knapheide...
