Phobos
Hi,
I am a rookie tractor owner - I bought a Massesy Ferguson 135 with a FEL. It has a flow control valve below the gear shift to switch between the operation of the FEL and the 3-pt arms. I am trying to figure out if there is there a way to control a double acting cylinder for my snow thrower chute. The tractor already has two hydraulic hose connections at the 3 pt. There is another 'plumbing' shut-off valve on the hose that goes to the loader that seems to divert flow to the right rear hose. The second rear hose seems to go back to the transmission. When I hook up my cylinder I can only get it to go one way. Can I use the using the pumping and draft controls to operate it or do I need an aux control valve?
I really appreciate all help.
