Coating inside of tractor fuel storage tank?
   / Coating inside of tractor fuel storage tank? #1
MNBobcat
I have a couple hundred gallon fuel storage tank on a stand. I've not used it yet. It does have a filter on it.
I'm wondering if I should invest in something like this in a gallon size ($103.00) to coat the inside of the tank and lock-in any loose rust before I use it? Looking for your thoughts. Don't know if that would be overkill and I should just rely on the filter.
   / Coating inside of tractor fuel storage tank? #2
I used one of those kits on an older backhoe that had some rusting in the tank. Pretty straightforward to use.
   / Coating inside of tractor fuel storage tank? #3
A coating is always a good thing, but in general it depends on how full you keep the tank and with what type of fuel. For instance, gasoline is hydroscopic so it will absorb some water where diesel will not. The difference being that the water will be sitting on the bottom of the tank, and possibly rust it.
Adams 6Ton Hydraulic Lime Spreader (A55301)
Adams 6Ton...
2024 CATERPILLAR 255 SKID STEER (A52705)
2024 CATERPILLAR...
2007 International 4300 Dump Truck (A51692)
2007 International...
2015 Volkswagen Jetta Sedan (A53424)
2015 Volkswagen...
LOT LOCATIONS (A54607)
2005 CATERPILLAR 740 - 6X6 OFF ROAD WATER TRUCK (A52706)
2005 CATERPILLAR...
