Just changed hydraulic oil and now have no hydraulics
   / Just changed hydraulic oil and now have no hydraulics #1
apring
Arcadia, FL
Kubota 4800
Everything was fine till I changed hydraulic oil and filters now have no hydraulics. The tractor, M4800 goes back and forth OK but no 3 Pt lift and no loader action. New oil is 10.5 Gals UDT super as called for by manual. Any ideas?
Thanks for your help
Andy
   / Just changed hydraulic oil and now have no hydraulics #2
The service manual for my B says if it gets an air lock like that, just turn the steering lock to lock several times. Maybe try that?
   / Just changed hydraulic oil and now have no hydraulics #3
Agree with Paystar - sounds like air in the system that needs to be purged.
When I tried to turn steering wheel I couldn't. I jacked up front end and after turning back and forth for a while the steering works good so I am sure you are right - it has to be air. Still no loader, 3 Pt lift and no PTO. Anyone know how to purge the entire system?
Thanks very much for your help guys.
Andy
   / Just changed hydraulic oil and now have no hydraulics #5
Bleeder valve somewhere perhaps?
   / Just changed hydraulic oil and now have no hydraulics #6
Try cracking open/loose a hydraulic line going to the steering hydraulic cylinder, then turning the steering wheel back and forth to purge the system of air.
   / Just changed hydraulic oil and now have no hydraulics #7
OP: no PTO ?? not clear how an air bolus in hydro line causes that ...but, I don't have a 4800
   / Just changed hydraulic oil and now have no hydraulics #8
Not sure but I thought all hydraulic pumps have a blender valve. Check your service manual. There may be more than one point to bleed also.
   / Just changed hydraulic oil and now have no hydraulics #9
Bad filter? Think I would drop filter and see if there is fluid in it. If you break open a pressure line you really need to be careful you don't get hurt with the spray...**** of a nasty injury!
Make sure all connections are tight...I would disconnect and then reconnect all fittings to FEL.
   / Just changed hydraulic oil and now have no hydraulics #10
You may have a suction leak preventing the pump from priming. Check for a double gasket on the filter in case the old gasket was stuck on the flange and you did not notice it. If there is a rubber hose in the suction line, pinch it and look for cracks. Try loosening the hydraulic oil filler cap on the tractor housing in case the vent is plugged.
Tractors with open center hydraulic systems will not have an air bleed as they are not necessary. Any air in the system will get pushed out to the tractor housing (oil reservoir).
Year: 2007 Make: Ford Model: Explorer Vehicle Type: Multipurpose Vehicle (MPV) Mileage: Plate: Body (A55788)
Year: 2007 Make...
2017 Ford F-250 Crew Cab Pickup Truck (A55788)
2017 Ford F-250...
2017 Ford Explorer AWD SUV (A51694)
2017 Ford Explorer...
2017 COTTRELL TRAILER (A55788)
2017 COTTRELL...
2000 KENWORTH W900 (A55745)
2000 KENWORTH W900...
2015 Chevrolet Silverado 2500 HD Crew Cab Pickup Truck (A55788)
2015 Chevrolet...
