jones6780
Gold Member
- Joined
- Nov 30, 2008
- Messages
- 422
- Location
- Lizella, Ga.
- Tractor
- Ford 1700 4wheel drive, Yazoo/Kees Max2 Zero Turn
Well I had my first experience with a stuck clutch. I had my tractor over at my mothers doing a little work and I had to leave it outside uncovered. It rained and was a week later before I got back to finish. When I started it up the clutch was stuck and would not release. I had a middle buster on and I blocked the clutch down and used the middle buster to put a load on it. Made several passes with no luck. Came back several days later and tried again. I moved to an area with tree roots and used the lift to regulate how much weight to pull. I tried to keep the tires spinning but not enough to spin and get stuck. Took several passes but it finally broke loose.
Guess I might need to block the clutch from now on.
Russell
Russell
