Need three foot, small bush hog for my 135d. Any suggestions?
   / Need three foot, small bush hog for my 135d. Any suggestions? #11
A month or two ago CL had a 38 inch listed in this area. Don't remember anything about it except I thought it was an unusual size.
Bruce
   / Need three foot, small bush hog for my 135d. Any suggestions? #12
I am trying to procure a cheap 5ft hog to use behind my ym2000 when there is the power to spare to run it. this would be in grass that is not too tall. In shorter grass i think the power is there for the larger mower over the 4fter i run. Much of my fields are junk and weeds and not thick grass and unless there 2 months or more of growth the 4fter can easily spin through it with even duller than bush hog blades should be.
   / Need three foot, small bush hog for my 135d. Any suggestions? #13
try howes don't see to many on CL they make a 3ft bush hog (new)
   / Need three foot, small bush hog for my 135d. Any suggestions? #15
When I bought my tractor it came with a 36" Howse rotary cutter so they are out there.
   / Need three foot, small bush hog for my 135d. Any suggestions? #16
I have ym165d, and I bought it from my neighbor with a 48" trailblazers rotary cutter. I have no problem with my 16 hp tractor using it. It my not lift it as high as I would like, but no problem mowing
   / Need three foot, small bush hog for my 135d. Any suggestions? #17
There are probably some people out there that would tell you to get a common 6 ft mower and remove one of the blades. Someone like the store clerk that suggested I use two 1/4x2 inch bolts instead of the one 1/2x2 inch bolt they didn't have.
Bruce
   / Need three foot, small bush hog for my 135d. Any suggestions? #18
Bruce
I would have liked to seen that application of two bolts in one hole...:)
   / Need three foot, small bush hog for my 135d. Any suggestions? #20
Totally unrelated to the Original question but to the tangent were on now.
Was in Home Depot and asked if they had grease fittings/zerks. First lady asked what there used on...i was caught so offgaurd as there on everything. I said machinery, tractors, implements, lawnmowers, cars...lots of stuff. she said go to mowers. I went there thinking if they had them they would be in the hardware drawers. Go to lawn section as the guys there and they said go the the hardware section. Go back see 2 other guys and they said automotive section after explainging what they are??? At this point i am pretty sure they dont have them. In the small automotive section they keep pointing out grease and grease guns!!! I said no i need the fittings those hook too???? (i had to get something else i did not go to HD looking for just grease fittings)
Long story short i got them at Orielys. were like $7 a package!!!!! i was like i ought to just replace the u joint for that price!! but i did not want to replace one and all the banging!
1994 Landoll Detach Trailer (A57148)
1994 Landoll...
Unused 84" Bucket Attachment (A55272)
Unused 84" Bucket...
2013 Ford F-150 Pickup Truck (A56858)
2013 Ford F-150...
MILITARY  BED TRUCK (A58214)
MILITARY BED...
Giyi 43" Disc Mulcher (A57149)
Giyi 43" Disc...
2352 (A58376)
2352 (A58376)
