hydraulic problems
   / hydraulic problems #1
dvaidm
Member
Harding mn
3020 john deere and 50 john deere
Today went to try to take the 3020 john deere in the field but the loader want go up or down. I check the fluid it was full the rear hydraulic goes up and down. The bucket or the arms don't move I think the pump is out if it is the pump do you recommend a new one or rebuild it. Or do you think it is something else?
P.s can't wait for deer hunting this Saturday yea
   / hydraulic problems #2
The usual first thing to check is the hydraulic connections, if the loader uses quick couplers.
12 days until firearms deer season in MI
   / hydraulic problems #3
Check hyd pump coupler between engine crankshaft damper & hyd pump to be sure it's not stripped out and pump shaft is turning with engine. How long since hyd filter was changed and sump screen checked/cleaned?
Where is the sump screen and the filter located at.
   / hydraulic problems #5
Hyd filter(parts key 28) is on LH side behind the battery. Sump screen(parts key 8) is between hyd filter & rear axle housing.
8' GREEN CHAINLINK FENCE (5) ROLLS (A51244)
8' GREEN CHAINLINK...
Pull-Behind Smooth Drum Ballast Roller (A51691)
Pull-Behind Smooth...
2014 Volkswagen Jetta Sedan (A50324)
2014 Volkswagen...
UNUSED AGT QK20R EXCAVATOR (A51243)
UNUSED AGT QK20R...
McDon 75D Flex Draper Head (A52349)
McDon 75D Flex...
2019 RBR Venturi 380 (A52128)
2019 RBR Venturi...
