1970's JD 310B (engine block heater)
   / 1970's JD 310B (engine block heater) #1
Aruba1
Remlap, AL
Ford Dexta, JD310B, Case 850B
Hi,
I am looking for an engine block heater for my john deere 310 A or B. It's the 3 cylinder diesel engine. I can't find a stock block heater, does anyone have any recommendation of what type will fit my block? Thanks
   / 1970's JD 310B (engine block heater) #4
Technically one can not use a block heater but can use a canister heater similar to photo.
   / 1970's JD 310B (engine block heater) #6
Yes that coolant heater should be ok.
   / 1970's JD 310B (engine block heater) #7
Technically that image of the tank heater is too high. The hot coolant from the heater should not travel "downhill" into the engine.
   / 1970's JD 310B (engine block heater) #8
Are you referring to the photo I posted?
Jim
Can you ya'll educate me why a block heater is a bad idea? Thanks
   / 1970's JD 310B (engine block heater) #10
No freeze(expansion) plug hole available to install a block heater on a 310B engine.
Adams Tender / Magnolia Trailer (A53473)
Adams Tender /...
2008 KZ Sportsman Police Bunk 5th Wheel Tri-Axle Travel Trailer (A54815)
2008 KZ Sportsman...
2018 Ford Fusion Hybrid Sedan (A53424)
2018 Ford Fusion...
1 pallet of miscellaneous hoses (A53117)
1 pallet of...
2019 MACK PINNACLE (A53843)
2019 MACK PINNACLE...
2012 UNVERFERTH 6-INCH FRONT WHEEL SPACER KIT FOR 10 BOLT HUB (A53473)
2012 UNVERFERTH...
