forks or no forks
   / forks or no forks #2
I did live without them on my last 5 tractors (Over 40 years). Now that I have a QA loader I bought a set and use them all the time. They were well worth the $524. I spent on them.
   / forks or no forks #4
Nope..... I use mine for moving logs all the time.
   / forks or no forks #5
You will use them all the time. Pallets, brush, logs, anything heavy, etc.. You'll have them on more than the bucket.
   / forks or no forks #6
I can, but I sure don't want to have to.
   / forks or no forks #7
What have u used them for
Used them for lifting Logs, brush, car engines, transmissions, car rear axle, pallet load of bagged salt, other implements to move them, front of car trailer lifted to undercoat it, ATV for easy service, shop air compressor, and anything else I need to lift.
   / forks or no forks #8
Can anyone tell me if they could live without pallet forks
Of course I could live without them.
That said, I won't be giving mine up. I unload pallets of chicken feed of the semi with mine. Also I move logs with them. I also stack firewood on some pallets I built that have side boards. Each holds between 1/3-1/2 a cord. I can sometimes cut a tree, split the rounds on the ground, then load on the pallet. That's lifting it by hand once. Then store the pallet wherever I want for a year. Then I can move the pallet to within 3' of my maple syrup evaporator (main firewood eater) then I lift each piece a second time to put it in the stove. Lots of guys talk about handling wood 7-8 times. More than 3-4 is too much for me. Pallet forks make that possible.
I also use them to dig in the ground (take 1 fork off), and to simultaneously remove and collect t-posts.
Worth it.
   / forks or no forks #9
As handy as the bucket and used almost as much. Would not be without the forks for the same reasons stated above.:thumbsup:
   / forks or no forks #10
WHAT???? No pallet forks???
New/Unused Quick Attach Auger with Three Bits (A51573)
New/Unused Quick...
2007 Ford Taurus SE Sedan (A51694)
2007 Ford Taurus...
2024 KMC 7406 LOT NUMBER 11 (A53084)
2024 KMC 7406 LOT...
1041 (A51572)
1041 (A51572)
2022 JOHN DEERE 6120M LOT NUMBER 191 (A53084)
2022 JOHN DEERE...
