bx 2670 4 wheel drive problems. I'm stuck on what the problem is :(
   / bx 2670 4 wheel drive problems. I'm stuck on what the problem is :( #11
Be sure your front tires are up to maximum inflation. If your tires "squat" when weight is applied, that changes the radius changing the turning speed causing binding. I agree with everyone else in that when you are on hard surfaces you need to be in 2WD.
   / bx 2670 4 wheel drive problems. I'm stuck on what the problem is :( #12
I was delivering a FEL bucket of dirt to my neighbor who has all concrete driveway and forgot about putting my B6 into 2 WD. When I turned it was leaving black rubber marks on the concrete from tire slippage. I backed up a bit and put it in 2 WD and no more marks. The fronts definitely spin faster than the rears which even on dirt will cause faster wear.
   / bx 2670 4 wheel drive problems. I'm stuck on what the problem is :( #13
Sounds like the nut behind the wheel is loose, and needs tightening. But the tractor is just fine, and that behavior is normal. Whether a tractor or truck, 4WD on dry pavement is going to cause binding and difficulty steering.
   / bx 2670 4 wheel drive problems. I'm stuck on what the problem is :( #14
One additional suggestion- check the fluid level in the front axle.
I had the same feeling in my BX2200 once while mowing and needed a significant amount of lube to bring the front axle up to operating level.
Thanks all.
I will also check the fluid level on the front axel just to be safe :)
   / bx 2670 4 wheel drive problems. I'm stuck on what the problem is :( #16
Thanks all.
Yep fluid level easy to check and as repete suggeste above, check your front tire pressure. The BX's lose front tire pressure easily. I ended up tubing both my fronts. Highly recommend.
2011 Ford Crown Victoria Sedan (A51694)
2011 Ford Crown...
2011 International WorkStar 7400 Chassis Truck, VIN # 1HTWGAAR1BJ325796 (A51572)
2011 International...
2025 New/Unused Wolverine Brush Cutter (A51573)
2025 New/Unused...
2012 INTERNATIONAL DURASTAR 4400 4X2 SERVICE TRUCK (A51406)
2012 INTERNATIONAL...
Pallet of 22 Misc Wheels (A51573)
Pallet of 22 Misc...
2012 Freightliner M2 106 Dump Truck, VIN # 1FVACXBS3CHBJ4624 (A51572)
2012 Freightliner...
