Never change engine oil brands?!?!
   / Never change engine oil brands?!?! #11
As long as you use quality products that meet the engine manufacturers specs and the equipment is in good shape to begin with, you are golden. Old wives tales are just that 'tales'. Originally they were probably based on a real world observation (along with a big dose of assumption and conjecture) but that was a long time ago and many things have changed except the tale.
DEWFPO
   / Never change engine oil brands?!?! #12
agree w/above. as long as your choice is diesel rated (as mentioned) you'll be fine. for your location, one might consider rotella t6 5/40 for those extremes but it's a personal choice & not to derail the thread.
   / Never change engine oil brands?!?! #13
I can switch oils??? Boy, that IS good news. It has been quite hard to find Arco Graphite these days.
   / Never change engine oil brands?!?! #14
LOL I worked in a ARCO station in HS back in the 70's..customers would go nuts when the garage mechanic changed their oil and put that in..they accused him of using used motor oil
   / Never change engine oil brands?!?! #15
That stuff sure worked good on our tractor that had a sticky lifter. Now there are oil additives that have molybdenum disulfide in them.
   / Never change engine oil brands?!?! #16
   / Never change engine oil brands?!?! #17
It used to be that at least some synthetics shrank seals. Change to them on an old engine [worn seals] could cause leakage. I dont know if this has been taken care of. Thats the only thing I know of to be concerned about.
larry
   / Never change engine oil brands?!?! #18
It used to be that at least some synthetics shrank seals. Change to them on an old engine [worn seals] could cause leakage. I dont know if this has been taken care of. Thats the only thing I know of to be concerned about. larry
I don't think it so much shrunk seals but more cleaned out the sludge and that made an engine find leaks.
Chris
   / Never change engine oil brands?!?! #20
I am glad too. It has been really hard to find this oil anymore
2021 Ver-Mac PCMS-3812 Solar S/A Towable Trailer Message Board (A52377)
2021 Ver-Mac...
REYNOLDS 100 - 8 YARD PULL TYPE SCRAPER PAN WITH DRAWBAR (A52748)
REYNOLDS 100 - 8...
20 ft. Shipping Container (A53117)
20 ft. Shipping...
2018 Toro Workman GTX Electric Utility Cart (A51694)
2018 Toro Workman...
