overheating NH 1725
   / overheating NH 1725 #1
Mtriangle
Pearce AZ
NH 1725
We have an overheating 1725 tractor with only 1700 hours. The radiator is leak and plug free, the thermostat is fine, and the pump seems to be fine (although I haven't pulled off the engine).
Could it be an issue with the drain petcock? Is there some other point in the system prone to blockage?
thanks
Mike
   / overheating NH 1725 #2
Have you taken a airhose and blown out the radiator fins ? be careful to not damage them , back when we were making hay it was a twice a day job or more to blow the rad clean.
   / overheating NH 1725 #3
^this and do not run water through them if your in dusty areas.. down here washing out radiators with water will make a nice concrete of dirt inside of them. also when is the last time your flushed your radiator
actually, yes, we pulled the radiator and had a shop run a pressure check and do a thorough cleaning. the problem remains and is sort of a mystery.
thanks
   / overheating NH 1725 #5
Can you notice a change in the tractor when its overheating or is the gage just sending a signal saying it is? I have had to replace the sensor on a NH that was showing the tractor was overheating. Ended up just being an electronic issue. If its not that then very well could be the water pump
   / overheating NH 1725 #6
thanks
Check the temperature with a thermometer. If it's still high then make sure that:
The rad cap is the correct pressure and is working correctly.
The drive belt is tight.
The lower rad hose is no collapsing when you rev the tractor
The air side of the radiator is not clogged.
To check the pump, remove the rad cap and run the engine till it heats up and you should see coolant coming into the top of the radiator when the thermostat opens. If you do the pump is working. To check the thermostat, get a thermometer and put the thermostat in a pan of water and heat it until the thermostat starts to open measure the water temperature and it should match the rating of the thermostat
Thanks Jerry--All good advice and we will implement, step by step. (The hose is old and I suspect collapsing is a possibility.)
2011 Kia Sportage SUV (A51694)
2011 Kia Sportage...
Takeuchi Skid Steer (A49461)
Takeuchi Skid...
2025 AGT MX-CRT23 (A50123)
2025 AGT MX-CRT23...
2019 KENWORTH T800 (A53843)
2019 KENWORTH T800...
VERMEER 605F ROUND HAY BALER (A51247)
VERMEER 605F ROUND...
2005 Ford E-450 Super Duty Ambulance (A51692)
2005 Ford E-450...
