Need help!
   / Need help! #11
Sorry about the diagram. Have good fuel flow all the way from the diesel tank thru the filters and into the fuel control. No lift pump or any kind of pumps that can go bad.
If you crack the injector lines do you have fuel?
If not then there is a problem in fuel pump. Make sure kill switch cable isn't broken. Is it key kill or manual? Search for things like that. If still nothing sound like maybe you need to have injector pump rebuilt.
   / Need help!
I will check that after it gets light tomorrow. The kill switch is manual. It seems to be functioning properly. Thank you.
   / Need help! #13
Check to be sure the fuel return line and fitting that attaches to fuel inj pump is open IE not plugged.
2014 Toro Workman HD 07369 Utility Cart (A51691)
2014 Toro Workman...
2016 Case 821F Articulated Wheel Loader (A54811)
2016 Case 821F...
2012 Ram 1500 Quad Cab Pickup Truck (A53422)
2012 Ram 1500 Quad...
Quick Attach EZ Axe Skid Steer Tree Shear (A53473)
Quick Attach EZ...
2017 FORD F550 XL SUPER DUTY BUCKET TRUCK (A51406)
2017 FORD F550 XL...
2016 KENWORTH T370 S/A SERVICE TRUCK (A51406)
2016 KENWORTH T370...
