show us a picture of your cab tractor if the manufacturer were asking what would u ad
   / show us a picture of your cab tractor if the manufacturer were asking what would u ad #11
Doors that open top half only like on a backhoe would really be nice when temperatures do not justify heat or A/C
   / show us a picture of your cab tractor if the manufacturer were asking what would u ad #12
I need more implements so there is more seat time.
Very very nice tractors keep the additional options coming
   / show us a picture of your cab tractor if the manufacturer were asking what would u ad #14
Heres my John Deere 5083e. Only thing I would want is free implements and diesel for life so I could be in it all the time!!!IMG_0778.jpgIMG_0795.jpgIMG_0779.jpg
Heres my John Deere 5083e. Only thing I would want is free implements and diesel for life so I could be in it all the time!!!<img src="http://www.tractorbynet.com/forums/attachment.php?attachmentid=399044"/><img src="http://www.tractorbynet.com/forums/attachment.php?attachmentid=399045"/><img src="http://www.tractorbynet.com/forums/attachment.php?attachmentid=399046"/>
That's the best answer I had yet free diesel would be a on my wishlist also
   / show us a picture of your cab tractor if the manufacturer were asking what would u ad #16
I've never been happy about the factory cab mirrors on my Kubota B-3000 factory cab. They tend to move around and I'm always having to open the cab doors to re-adjust them.
   / show us a picture of your cab tractor if the manufacturer were asking what would u ad #17
Coming soon...........
What would I add/change? My boys available to put it together for me!
   / show us a picture of your cab tractor if the manufacturer were asking what would u ad #18
I like the interior layout of my cab.
A few things I would like to see is the Mfg. change or install are:
1) Extra toggle switches on the right side column that you could use for adding additional lighting or whatever. Other than factory switches aftermarket ones the right size to fit the factory openings are hard to find.
2) Drain holes in the mirror bottoms. I noticed mine were full of water from using it in the rain. I drilled drain holes in mine. They were half full. Had I left the tractor outside and the water froze it would have popped the mirrors out or at least broke them. (No pic of drain hole)
3) Mirrors are too close to door when opening (1"). I constantly bump them getting in and out of cab. I am going to re design my mount brackets so they can be more forward. The brackets lock in place where they are or 90* forward but not on the 45* point see pics.
pic 1 shows door as in opens and just misses the mirror. 2 is with door closed. 3 is where I am going to move mine when I re design the bracket.
4) I second having split or two piece doors that can be easily removed when not needed. Mainly the top half for the times we don't need heat or AC.
That's a beautiful tractor
2020 Kinze 3505 High Speed 6/11 Planter (A56436)
2020 Kinze 3505...
2021 NEW HOLLAND GS72 HD FRONT MOUNTED BRUSH CUTTER (A57024)
2021 NEW HOLLAND...
Fork and Frame Skid Steer Attachment (A56857)
Fork and Frame...
2013 FORD F-350 XL SUPER DUTY- FLAT BED (A58214)
2013 FORD F-350 XL...
KBH 25 TON TENDER (A56435)
KBH 25 TON TENDER...
2015 CAT D5K2 LGP (A55272)
2015 CAT D5K2 LGP...
