Water Pump Bad?
   / Water Pump Bad? #1
Lutzy48
Member
Miles City, MT
Ford 1710
I was checking the fan belt tension on the Ford 1710 I bought recently (466 Hours) and I noticed that the fan/pulley assembly was loose. In looking at the shop manual I have to assume the water pump bearing is bad. What puzzles me is that it is not leaking coolant. Thoughts?
   / Water Pump Bad? #2
Maybe the bolts holding the fan and pulley to the pump are just loose.
   / Water Pump Bad? #3
The water pump on my 1710 wobbled bad but did not leak. I decided to change it before it did leak and risk engine damage.
   / Water Pump Bad?
Wolfy, how many hours on it when it did this? I decided I am going to go ahead and order parts to rebuild it. Do you know if the O-ring behind the plate is a standard size, or should I order one with the other gaskets?
   / Water Pump Bad? #6
I got it used with 1,900 hours. It wobbled when I bought it. I have no idea if it had ever been changed before. Instead of rebuilding it, I got one from a dealer. However, I have since also changed the water pump on the 1600, which was very similar. That one I got online and it was far cheaper. For the low cost I would not bother rebuilding one, but if you do, it would be logical to change all of the gaskets and O rings.
   / Water Pump Bad? #7
i got an aftermarket one for my 1710 many years ago and it has held up just fine. i don't remember if mine leaked when it busted. it just stopped turning and started burning the belt up.
   / Water Pump Bad? #8
Changed mine (1700, but think it's the same pump) last weekend @ just over 2,000 hours because it was dripping out the weep hole. There was no bearing wobble yet. I do have to say that was the easiest water pump change i have ever done in my entire life. Almost a pleasure compared to some I've done :) Also found on line for much less $$ than dealership.
   / Water Pump Bad?
I ended up by an entirely new water pump at a local tractor dealer for about $110. Fortunately they carry a pretty good stock of Ford/New Holland Parts even though they seem to sell more Kubotas than anything else.
   / Water Pump Bad? #10
That is a good price, actually. The aftermarket units like mine from Ebay range from $75 to $100. And it is probably blue, where mine is grey.
2015 Ford Escape SUV (A50324)
2015 Ford Escape...
New/Unused 7ft 20 Drawer Stainless Steel Workbench (A51573)
New/Unused 7ft 20...
Hustler Zero Turn Mower (A51573)
Hustler Zero Turn...
Modine Shop Heater (A51573)
Modine Shop Heater...
1988 Ford F-250 Pickup Truck, VIN # 1FTEF26N1JNA71750 (A51572)
1988 Ford F-250...
2007 Reitnouer 40 Ton T/A Heavy Haul Flatbed Trailer (A52377)
2007 Reitnouer 40...
