Size of wire for a 12 volt run.
   / Size of wire for a 12 volt run. #11
dont neglect the ground. especially if you just found some little metal screw or bracket under the dash to ground things to.
   / Size of wire for a 12 volt run. #12
Work has kept me too busy to get any thing done on the truck wiring yet.
I am still trying to decide on how I want to do it.
Has anyone used one of the Blue Sea Systems 187-Series Surface Mount Circuit Breakers. They serve as both a switch & breaker.
Amazon.com: Blue Sea Systems 187-Series Surface Mount Circuit Breaker: Sports & Outdoors
Powerwerx has a lot of good stuff and good pricing. The Bussman version is quite a bit cheaper if you do not need marine grade, have these on my Jeep for the radio power feed along with 4ga wire going to the aux battery pack with smart relay isolator.
Resettable Circuit Breaker Cooper Bussmann
David Kb7uns
Steve, I will be running a ground wire from the battery to the rear of the truck.
David, I first looked at the breaker you linked to, but I also want a switch on the line. The one I linked to is a switch/breaker.
   / Size of wire for a 12 volt run. #14
DO NOT USE A CIRCUIIT BREAKER. I test many and most 30 amp breakers won't open the circuit until way over 60 amps.
What kind of truck? Why do this the hard way? Why not utilize the power already there for the camper plug or 7 way plug at the rear. If it's a Chevy most likely the wire for the power circuit simply needs a fuse installed or eye terminal bolted up to the fuse panel under the hood. 6 gauge wire to the rear is ridiculously large and 12 should be plenty.
Post the VIN or make to make it easier.
Regards. Fred
   / Size of wire for a 12 volt run. #16
12ga will be too small
Maybe for a 7.5 horse air compressor, he's blowing up his air bags not sandblasting. 12 Gauge will handle 40 amps DC easily.
Fred
   / Size of wire for a 12 volt run. #17
I agree with Fred. How many amps are you running threw the starter wire? What gauge is it?
   / Size of wire for a 12 volt run. #18
MOST starters draw 200 amps cranking, depending on load, temp.
GM uses 12 gauge for their windows and seats respectively, THOSE circuit breakers are rated at 30 amps and don't pop until well over 60 some I tested over 90. Last year I fixed a Silverado window circuit that fried the complete body harness after a short under the driver's seat grounded the wire. I bought a new breaker from GM and tested it before installing it. 90 amps before it tripped.
Circuit breakers are junk and shouldn't be used. Fuse the circuit as close to the power source (battery +) as you can. A 30 amp fuse is more than enough.
Regards, Fred
   / Size of wire for a 12 volt run. #19
Fred
And those figures are not for max amps with a large voltage drop. For 5% voltage loss and 12ga it is less then 4 feet run.
   / Size of wire for a 12 volt run. #20
The Bussman and the generic knockoffs all can be used as a on off switch, push button trips off and lever resets and closes. Use them on my Ham radio vehicle install to feed the radios and 150AH battery pack in the back of my jEEP. I use both fuses and circuit breakers.
David Kb7uns
KUBOTA SVL75 ENCLOSED CAB (A52706)
KUBOTA SVL75...
PENDING SELLER CONFIRMATION  READ BEFORE BIDDING (A56435)
PENDING SELLER...
1999 CLEMENT END DUMP (A53843)
1999 CLEMENT END...
2000 Trail King TK70SA-48.2 T/A 43 Ton Hydraulic Slide Axle Step Deck Trailer (A52377)
2000 Trail King...
TORO TRX20 STAND ON TRENCHER (A52707)
TORO TRX20 STAND...
