FEL hydraulic valve sticking
   / FEL hydraulic valve sticking #1
ZGB32
Worcester, MA
Kubota B2620
I need help!!!
Brand new kubota b2620, and the FEL valves stick, has been from day one.
If the FEL is not used for 15 minutes, and I try to move the bucket say, down just a little, as I push on the lever, it does not move. As I increase pushing it, all of a sudden, I feel something release, the valve moves, but by then, it moves too much, and the bucket drops too quickly. After that, when this whatever frees up, it works fine, and I can move the bucket slowly and under control.
Happens on both up/down and curl/dump. Then after it frees up, if I don't use the FEL for 15 minutes, it happens all over again.
Same problem with the engine running or not. Even if I lower the FEL and stop the engine, release all hydraulic pressure. Then let it sit for 15 minutes, same problem.
Took it into the dealership, and they can't find anything wrong. This is not normal.
Any help/suggestions would greatly be appreciated.
Zoltan
   / FEL hydraulic valve sticking #2
Have you checked to make sure the lock lever that locks the control lever from moving is completely disengaged?
Yes I did, it is disengaged.
   / FEL hydraulic valve sticking #4
Some times, if a valve body is tighten down too much, the valve will warp and cause the spools to bind..
Try loosen the mounting bolts and try it.
There is a slight bump when you use regen, and much harder bump when using float.
Bucket tilt up and loader arms up should be a smooth operation.
   / FEL hydraulic valve sticking #5
ZGB32,
Since it does this with no pressure or load on the sytem it does sound like some form of mechanical binding. Does your B2620 have direct mechanical linkage to the valves or cables? On my Branson the ball joints on the linkage were rusty and caused binding. I had to lube the heck out of them to get them to move freely.
Can you access the valve easily and remove the linkage connection to the valve spools. If yes try moving the joystick to see if you feel any binding. If no then this would point to something in the valve binding like JJ stated above.
All movement from center position should be smooth until you get to detents.
   / FEL hydraulic valve sticking #6
There have been several threads about sticking Kubota loader valves over the years. It happened to me and I replaced the long, hex shaped components that protrude from the valve body. Everyone seemed to agree that it was condensation trapped in those hex parts that rusted the detent mechanism and/or froze when it turned cold enough. Some people drilled a drain hole to cure the problem. Post back if you can't find it on a TBN search.
   / FEL hydraulic valve sticking #7
I think this is the best thread: http://www.tractorbynet.com/forums/...g/127095-loader-float-freeze-up-winter-3.html
ZGB32,
Linkage to valve is direct, no cable. Dealer lubed the linkage, but I will check tomorrow, make sure it moves freely.
   / FEL hydraulic valve sticking #10
Rust from the condensation was also a problem with locking up the detent. I bought new parts for mine but once I disassembled it, I think some penetrating oil would have fixed it.
2019 Allmand Night-Lite V-Series S/A Towable Light Tower (A52377)
2019 Allmand...
2017 Bomag BMP 8500 Walk-Behind Articulated Tandem Compactor (A51691)
2017 Bomag BMP...
2014 Ford Taurus AWD Sedan (A51694)
2014 Ford Taurus...
U56 ELECTRIC FIRE PUMP MOTOR (A51406)
U56 ELECTRIC FIRE...
FRONTIER WR3210 LOT NUMBER 120 (A53084)
FRONTIER WR3210...
Craftsman 917.257632 42in Riding Mower (A51694)
Craftsman...
