BX 200hr club?
   / BX 200hr club? #11
Probably going to jink myself, but mine is coming up on four years old and I have just under 440 hours. I did the 400 hour service this Spring. That was a big one with engine oil and filter, HST oil and filter, coolant change, fan belt adjustment, front axle pivot bolt torque check, greasing, and I can't recall what else - oh yeah, air filter and put in a racor fuel filter in place of the OEM under-floor-board el cheepo filter.
Anyway, other than I broke one of the rear "brake" light lenses, can't recall any repair items per se. That or I"m just getting too old to remember "stuff".
   / BX 200hr club?
Probably going to jink myself, but mine is coming up on four years old and I have just under 440 hours. I did the 400 hour service this Spring. That was a big one with engine oil and filter, HST oil and filter, coolant change, fan belt adjustment, front axle pivot bolt torque check, greasing, and I can't recall what else - oh yeah, air filter and put in a racor fuel filter in place of the OEM under-floor-board el cheepo filter. Anyway, other than I broke one of the rear "brake" light lenses, can't recall any repair items per se. That or I"m just getting too old to remember "stuff".
How do your boots look like on the front axle turnbuckles? Mine
are shot.
   / BX 200hr club? #13
are shot.
Last I looked at them they were fine. I see a lot of posts on them tearing, but so far so good for mine. I dont work in brush much, so that may help explain my luck.
   / BX 200hr club? #15
Besides normal maintenance, put me down for a busted hydraulic line due to rubbing that I didn't detect.
   / BX 200hr club?
Oh and Slim, my new boots are still in the bag. I gave it a quick attempt a couple weeks ago but couldn't easily dismantle the joint. Now it's getting cold!
   / BX 200hr club? #17
I did it on mine it was a snap. First thing I discovered was that you can't put the jack on the axle it will bind the joints up.
   / BX 200hr club? #18
I need to check that out on mine. Looks like it is the back hoe area....did you use the backhoe a-lot?
   / BX 200hr club?
How did you dismantle the joints?
Cherokee, I am talking about the boots on the front axles/knuckles.
   / BX 200hr club? #20
I just did my 200 hour on my 3 year old BX 1860. All went well except I broke the headlight assembly for the second time, and I am unable to install the new ($120) assembly--just won't fit right. So, I now have a headlight-less BX. Fortunately, my winter cab has good lights mounted up high.
2000 POLARIS MAGNUM 325 ATV (A51406)
2000 POLARIS...
PAIR DIAMOND PLATE DBL AXLE FENDERS (A51247)
PAIR DIAMOND PLATE...
2023 JOHN DEERE 2032R LOT IDENTIFIER 151 (A53084)
2023 JOHN DEERE...
New/Unused Gold Mountain Container Shelter 20ft x 40ft (A51573)
New/Unused Gold...
UNUSED FUTURE 20' BI-PARTING WROUGHT IRON GATE (A51248)
UNUSED FUTURE 20'...
