Hamm8
I wood like to build a winch plate on the Kubota's bumper or hitch mount to haul skid out some logs, Keeping in mine that I 'm putting on a warn 8000 on the front . I need a plan that will address one that the winch can be moved to the rear if possible. Two have the cable come up to the top of the plate out a pulley like the woods winch on a tractor, this to keep the log up while skidding out . Three strong enough not to bend the plate under the weight of the log I'm hauling out . The log no long 12-16tf 12" in diameter . if larger the 12"diameter plan to cut the log shorter. Don't know if this is at all possible . And knowing that much metal on the front might not be able to remove it to the rear hitch. One other thing do I or will I have to beef up the front suspension ?
Had a 6X4 gator with a 2500lbs warn winch and didn't do to bad in the woods . it was 14yrs old . The 8000lb warn is big do to a great deal . so I'm putting it to use. . This idea comes from just thought , not facts , so can it be done , or ??????????????????????
Thanks for any ideas help plans . Cheers Nova Scotia .Canada
Hamm8
Hamm8
