Keeping new construction comfortable inside during winter
   / Keeping new construction comfortable inside during winter #1
greenmojo
Gold Member
Badger Mountain, WA
John Deere 4300, John Deere 450C
Hey all;
While building the new house out here in central WA state, the cold has moved in and although I don't mind working in the cold, it would be nice to be inside working in a light jacket rather than being a carhartt mummy.
The house is framed, roofed and sided. I am working on plumbing, electrical and mechanical and of course can't insulate until inspected.
The two major issues in the house with the cold is the ridge vent at the top of the house that runs 60' the length of the house, and on each side of the house, all of the bird blocking that lets a good breeze through if the wind gets up under the porches.
I wanted to hear some creative ideas on keeping some heat in over the next several weeks while I work away inside.
One thought was to take some 6mil plastic and just run it across the bird blocking with staples to temporarily keep the breeze out, and do the same at the top for the ridge vent. Then run some 80,000 BTU heaters in there to get some work done.
Thoughts and more ideas or experience?
~Moses
   / Keeping new construction comfortable inside during winter #2
Your solutions are on the right track and about all you can do at this point. Check with your inspector, by now you have some kind of a relationship with him and hopefully he has seen enough to have a little mercy on you and might allow some insulation, providing that you are willing to remove any of it for future inspections. Carhart mummy, I hear ya!!
   / Keeping new construction comfortable inside during winter #3
I framed and roofed my place over winter. I dressed in layers and started cold mornings with the heavier work or by pounding nails.
   / Keeping new construction comfortable inside during winter #5
I have a kerosene/diesel fueled blast heater p_03.jpg. There are many brands and sizes, the big box stores have them. Even most of the kerosene ones will also burn diesel fine. I use diesel (off road). My steel shop is not heated except this way. , I have used them on many construction sites and tent type fab shops here in the PNW. Just make sure the fumes have an escape route like open some windows and doors. They heat a small area close to your work very nicely. Over there in your valley the moisture in the combustion gases will probably freeze in droplets or icicles above. They will sublimate when the heat is off and go away if they stay frozen.
Rom
   / Keeping new construction comfortable inside during winter #6
Stop the blow though, stop the excess feeling of cold.
Small heater will work.
Luck
   / Keeping new construction comfortable inside during winter #7
Only 80k BTU? I had 300k+ in mine last winter, and it was "workable" at best. It was a bullet style long tube burner (we called it the dragon) that needed external air to feed it to stop CO issues. I took out a window and framed over it with OSB and some 2x's to make an opening for it that was enough but not crazy. Mine was also plumbed directly into the natural gas, or could have been set up for propane if needed. Gas bills were ~$450/mo for the 3 main months of winter. Sucked, but no choice. It was a brutal winter too.
Good idea, I can ring them up and see what others are doing that is convenient. I'm sure L&I (inspects electrical separate from building department) won't be so keen on me covering anything up.
Work harder.
I knew that was coming...
I was planning on two 80,000 BTU heaters. I can always add more if necessary. At least now I know I'm on the right track... Its no fun at all going into a 15 degree building that stays cold long after the sun has broken the basin.
I'd prefer to crank some heaters on, start working and before I know it, its 90 degrees and my wife has brought me a pitcher of piña colada.
~Moses
   / Keeping new construction comfortable inside during winter #9
Have your wife do the work 'till it's 90*, then bring her the coladas!
   / Keeping new construction comfortable inside during winter #10
Without insulation, the heat load will surely be greater, but for the sake of comparison, my corn stove would produce about 8000btu/hr and heated the entire 1300 sq ft floor toasty hot. The key thing is that it runs all the time, does not cycle on and off like a furnace. I have been heating a drafty barn with no insulation whatsoever, probably 14 ft ceilings (base of the rafters) 40x120 ft and I take the chill off using a 45k torpedo heater. No it will not get down to shirtsleeves, but I did get warm enough to take off my jacket and work in my flannels. Obviously with such a large building, I had it "pointed" towards the area where I was working...
2003 International 7400 T/A Heil 12 CuYd Dump Truck (A51692)
2003 International...
DIXIE CHOPPER BLACK HAWK HP ZERO TURN MOWER (A54757)
DIXIE CHOPPER...
2013 Ford Transit Connect Van (A52377)
2013 Ford Transit...
2005 Ford F-650 2,000 Gallon Water Truck (A53422)
2005 Ford F-650...
UNUSED LANDHONOR UNIVERSAL ADAPTER PLATES (A54757)
UNUSED LANDHONOR...
2008 Ford F-550 Reading Enclosed Service Truck (A52377)
2008 Ford F-550...
