Newbie 4W CUT drive train question
   / Newbie 4W CUT drive train question #1
biodegraded
Lane County Oregon
MF 1754
For the ubiquitous 4W CUT drive train - how many differentials? I assume there has to be a center diff to decouple front from rear, but what about the axles? I mean, they're tractors going a few mph, usually on dirt, so does it matter if tires slip on a turn? Just wondering.
   / Newbie 4W CUT drive train question #2
Two differentials - one for the rear, one for the front, and no differential between the front and rear. Front unlocked from main transmission by operator when operating on hard surfaces - asphalt, concrete, etc.
   / Newbie 4W CUT drive train question #4
Also, brakes on the rears, not the front. You only get braking action up front in FWD when the drivetrains is locking the front to the rears with the brakes.
   / Newbie 4W CUT drive train question #5
Becomes especially important when going down a steep hill with FEL and load...... ;)
   / Newbie 4W CUT drive train question #6
Boy, Howdy!... Hang on, and ride em cowboy, and hope you don't get turned sideways.
   / Newbie 4W CUT drive train question #7
3,500lbs L3200 in 2wd. 100-150lbs gate/panel on the backs of my pallet forks on the loader (over 1000lbs lift capacity). 4% grade towards the back of my barn where I store the panels.
I now always make sure to leave it in FWD & am trying to figure out how to patch 2 rectangular holes in the wall of my barn... It doesn't take much, I was at under 20% capacity by a good bit.
Let off the HST go pedal to stop. Didn't. Hit the brakes. Still didn't. Hit the the siding. Still didn't. Finally caught a pole & stopped.
Left some nice skidmarks on the ground (rear wheels only) not to mention in my shorts.
I knew about the issues, but assumed they only applied to being near capacity on the loader.
2018 Kubota U17 (A53317)
2018 Kubota U17...
2020 PETERBILT 567 (A58214)
2020 PETERBILT 567...
2012 JOHN DEERE 13-INCH REAR WHEEL SPACER FOR 10 BOLT HUB (A55315)
2012 JOHN DEERE...
2014 MACK CHU  PINNACLE DAY CAB (A55745)
2014 MACK CHU...
New Holland WorkMaster 37 (A53317)
New Holland...
cummins generator (A56857)
cummins generator...
