Ideas for securing 20X35 metal carport awning
   / Ideas for securing 20X35 metal carport awning #1
SCOOBY14B
Cleveland, Georgia
Kubota BX2660 Ansung B2504 FE loader and Kubota MMM
I'll be ordering a 20X36 "Carolina Carport" style carport soon.
It will be open sides and ends. I'll be installing it on dirt/gravel. I'm trying to decide the best way to secure it.
Should I go with the just standard 30" rebar anchors, standard anchors with 4 auger anchors (one on each corner), or concrete block "footings"?
I'll be storing our 5th wheel, truck, tractor, etc under it.
About the highest winds we ever get here are 30-35mpg...with an occasional gust to 50...but that's rare.
Thanks in advance
   / Ideas for securing 20X35 metal carport awning #2
Just go with "Hurricane Anchors" like are used on mobile homes.
   / Ideas for securing 20X35 metal carport awning #3
Augers if you can get them in. It well take more then 4.
What about 4 of the augers along with the 30" standard rebar pins?
   / Ideas for securing 20X35 metal carport awning #5
I would go with the augers/anchors and not use the rebar pins. The amount of money you save buy using the rebar pins isn't worth the possibility of the carport moving or being lifted off the ground. Agrisupply has pretty cheap anchors.
Agri Supply - Search
   / Ideas for securing 20X35 metal carport awning #6
I laid down 3/4" stone, had the Carolina Carport guys use the mobile home anchors. Very satisfied.
2009 PETERBILT 388 TANDEM AXLE DAY CAB (A51219)
2009 PETERBILT 388...
2017 Kawasaki Mule 4010 4x4 Rescue Utility Cart (A50322)
2017 Kawasaki Mule...
2015 MACK CXU613 TANDEM AXLE DAY CAB (A52141)
2015 MACK CXU613...
2013 INTERNATIONAL 4300 26 FT BOX TRUCK (A51222)
2013 INTERNATIONAL...
2004 MACK GRANITE CV713 DUMP TRUCK (A51406)
2004 MACK GRANITE...
2014 INTERNATIONAL 7400 SBA 42 LUBE TRUCK (A51406)
2014 INTERNATIONAL...
